Scottish Electrification updates & discussion
20 Mar 2012
The alloa line is completely wired whilst Stirling itself is wired through most of the lines as far south as bannockburn apparently.
Meanwhile, line is wired as far North as bridge of Allan and masts are starting to appear in dunblane. Correct me if I'm wrong as I'm not from the stirling area as going by what other people are saying on scot-rail.co.uk
59CosG95
18 Aug 2013
Beeston (Notts)
Thanks for the updates Jamie - I'm posting a mini - update "7.1" below this highlighting the progress made each day. Any updates you (or indeed anyone else) give would be hugely appreciated!
mcmad
11 Mar 2015
Took a walk earlier, the gap in the masts around Cowie is now filled with TTC's and catenary strung. Hope the project is back to turn the muddy ploughed field back into a navigable walkers path before too much longer after the utilities diversions.
Will be in Stirling tomorrow so will try and see whats happening in the station area.
Jessicas Dad
1 Mar 2015
At the new footbridge at St Ninians LC the Perth bound line is fully wired including the contact wire but the Larbert bound line doesnt have the contact wire yet.
At the overbridge over the Bannock Burn a bit further South though both lines have the contact wire as far as I could see.
Ross
Fougasse
3 Apr 2018
Catenary and contact are now up on both roads through Bridge of Allan, finishing just short of Kippenross Tunnel.
59CosG95
18 Aug 2013
Beeston (Notts)
Scottish Wiring Progressometer - Post 7.1 (SDA blockade mini-update, dated 15th October 2018)
Larbert - Stirling - Dunblane/Alloa
Line blockaded from 14/10 to 21/10 (inclusive) for wiring between Dunblane/Alloa and Larbert. Any updates during and after the works would be greatly appreciated.
Update for 7.1: The Alloa branch is now fully wired.
At Larbert, both main lines and the Down Passenger Loop are fully wired.
Earth wires now up around Plean; masts are fully bedanglied around the M9.
Update for 7.1: Wires now extend south from Stirling to Bannockburn; no contact wire at St Ninians LC on the Up line yet.
Kerse Rd bridge nearly finished - due to be reopened on 19th October 2018.
Within Stirling, many masts/TTCs/portals are now up.
  • Wires up over bay platforms 7 & 8, affixed to a multi-track portal.
  • From Stirling Middle SB to the platforms, a large number of TTCs and portal booms (all with SPS) have gone up.
  • Update for 7.1: Wires assumed up through platforms 6 & 9.
  • C&C wires now up through P10 (the former Motorail bay) - insulators have yet to be spliced in on the termination SSA.
Update for 7.1: Wires now extend north from Stirling to Bridge of Allan, finishing just short of Kippenross Tunnel.
On the viaduct over the Forth (on the Perth Lines), catenary wire & droppers are now accompanied with contact wires.
Update for 7.1: Masts now starting to go in at Dunblane.
Glossary of Terms
SPS - Small Part Steelwork; the "dangly bits" that hang off the masts e.g. registration arms.
TTC - Twin Track Cantilever; the "gallows" style masts with 2 sets of small part steelwork on it.
CIS - Customer Information Screen; the "dot matrix" displays shown on most modern stations.
Mingulay
5 Mar 2018
As a Dunblane commuter it is good to see the end in sight, despite this week of long journeys to work by car and much disruption in the last few years .
It is however bitter sweet. Given the dawning realisation that for us , new trains and the new timetable will deliver fewer direct journeys , less peak time capacity and slower journeys . Not what we were all told was the new dawn of Scotlands best ever railway. Feeling very let down by the Scotrail Alliance . I hope the timetable will be revised to at least no worse than what we have . If electrification beyond the obvious benefits of cleaner and more reliable trains is to be justified , it cant be just a few minutes saved for Glasgow Edinburgh commuters , but no improvements for others on the routes electrified?
matchmaker
8 Mar 2009
Central Scotland
Alloa line still has a gap at the Stirling end - from Causewayhead Junction over the Forth Viaduct. The new LED signals at Stirling North appear to have been commissioned.
59CosG95
18 Aug 2013
Beeston (Notts)
Scottish Wiring Progressometer - Post 7.2 (SDA blockade mini-update, dated 16th October 2018)
Update for 7.2: The Alloa branch still has a gap from Causewayhead Junction over the Forth Viaduct.
  • Wires assumed up through platforms 6 & 9.
Update for 7.2: New LED Signals at Stirling North appear to have been commissioned.
Glossary of Terms
Jessicas Dad
1 Mar 2015
Was out for some shopping earlier on and took a chance to check on St Ninians LC again. All droppers now in place and contact wire in place on both lines.
The drove past the station and although I couldn't stop, could see that the insulators are now in place at the end of P10. Lots of orange jackets on P10 and P4 & 5 and a Unimog or similar on the P4 / 5 lines on the N side of the Shore Road bridge (I think - could have been on the Alloa lines).
And slightly off topic for this but road signs being fitted to the Kerse Road bridge so all looking good for it re-opening on Friday.
59CosG95
18 Aug 2013
Beeston (Notts)
Thanks for the updates there, I'll get that in for tomorrow's mini-update.
mcmad
11 Mar 2015
Wandered over the glass bridge at Stirling station today and all lines bar the Down (P3) had full OLE in place through the station. P3 had catenary and droppers but a drum carrier and 3 MEWP's passed so probably fully completed by now.
MadMac
13 Jun 2008
Moorpark, CA
Replacing the last two full-size semaphore arms in the Stirling area.
59CosG95
18 Aug 2013
Beeston (Notts)
Scottish Wiring Progressometer - Post 7.3 (SDA blockade mini-update, dated 17th October 2018)
Wires now extend south from Stirling to Bannockburn; Update for 7.3: contact wire at St Ninians LC on the Up line has now gone in.
Update for 7.3: Within Stirling, all lines have full OLE in place through the station.
  • The wires over P3 (the Down Dunblane) are probably complete.
  • The wires over P10 (the former Motorail bay) now have their insulators spliced in on the termination SSA.
Glossary of Terms
59CosG95
18 Aug 2013
Beeston (Notts)
Scottish Wiring Progressometer - Post 7.4 (SDA blockade mini-update, dated 18th October 2018)
Wires now extend south from Stirling to Bannockburn over both lines.
  • Update for 7.4: Single Insulated Cantilevers have been cleverly installed within the canopies of P3/4.
Wires now extend north from Stirling to Bridge of Allan, finishing just short of Kippenross Tunnel. Update for 7.4: Kippenross Tunnel has now been "wired" with rigid conductor bars.
Update for 7.4: Virtually all masts now in at Dunblane.
Fougasse
3 Apr 2018
Kippenross Tunnel wires are installed on Furrer and Frey cantilevers, not ROCS (conductor bars).
matchmaker
8 Mar 2009
Central Scotland
Alloa branch now appears completely wired. As well as the LED signals at Stirling North, the starter on the Perth line has a banner repeater (the signal has been moved several hundred metres nearer Dunblane than the original semaphore position).
snowball
4 Mar 2013
Kerse Road opened today:
https://www.networkrail.co.uk/feeds/network-rail-opens-8m-stirling-railway-bridge-early/
Network Rail today (Friday 19 October) opened Kerse Road bridge in Stirling a week earlier than planned.
The A905 Kerse Road has been closed since April while engineers demolished and replaced the road bridge over the railway to the south of Stirling station.
The project is part of a wider Scottish government-funded investment being delivered by Network Rail ahead of the electrification of the route this winter.
The new £8m structure has delivered a significant increase in the width of the bridge offering the potential for the council to enhance the carriageway in line with Stirling’s needs – and in keeping with the city’s transport strategy.
Baillie Chris Kane, along with two of the city’s elders, 100-year old Mrs Mary Cooper and 92-year old Mrs Betty Imrie, were on-hand to officially re-open the structure.
Iain McFarlane, Network Rail’s route delivery director, for the Stirling-Dunblane-Alloa (SDA) electrification project said: “The reconstructed bridge at Kerse Road enables the electrification of the rail lines through Stirling but also delivers a stronger and wider structure which will stand the city in good stead for many years to come.
“We understand the impact this closure had for road users, businesses and communities adjacent to the site, but we have worked proactively with Stirling Council to minimise disruption and maintained close communication with the wider community to update on progress throughout.
“We have been heartened by the positive feedback we have received from those impacted by the work who understand that this scale of investment cannot be delivered without some degree of disruption.
“We thank everyone for their patience while we carried out this important work.”
MadMac
13 Jun 2008
Moorpark, CA
Just to expand on this, the “Starter” for Stirling North is now the former SN38 (now SN39) which was the Bridge of Allan Down IB Home - I understand that’s been the case for some time. The relocated/renewed SN37 now has, as stated, a banner repeater.
59CosG95
18 Aug 2013
Beeston (Notts)
Scottish Wiring Progressometer - Post 7.5 (SDA blockade mini-update, dated 19th October 2018)
Update for 7.5: The Alloa branch has now been wired over the Forth Viaduct to Causewayhead Junction; thus completing the wiring on the branch.
Update for 7.5: Kerse Rd Bridge now reopened.
Wires now extend north from Stirling, through Bridge of Allan, and through Kippenross Tunnel. (perhaps not?)
clc
31 Oct 2011
https://www.dailyrecord.co.uk/news/local-news/east-kilbride-msp-told-improvements-13430755
Hopefully something is on the way for EK and Barrhead though i think it might just be more 156s !
It certainly sounds like infrastructure improvements are being developed:
“Transport Scotland, Network Rail and ScotRail are working together closely to develop plans that will deliver better resilience, more capacity, reduced emissions and major passenger benefits during the coming years. Detailed work has already commenced to assess the most economic means of delivering those outcomes and this will involve on site surveys to inform decisions about how best to proceed.”
gingertom
19 Jun 2017
Kilsyth
Altnabreac
20 Apr 2013
Salt & Vinegar
Platform extensions to take 8 x 23m coaches would be a good start that would also be useful even once you have doubled and electrified the line. Could be relatively quick and simple to achieve as well.
8 x 23m should really be the new standard operating length for the busier lines in the Central Belt. E-G via Falkirk and Glasgow - Ayr are based on that now so any platform lengthening or enhancements on busier lines should be using that as a minimum to aim for.
