Deltic1961
- Joined
- 30 May 2018
- Messages
- 645
Just wondered, fastest they run on my local line (Dyce to Aberdeen) is 75mph.... and that's only for probably 3 or 4 miles. Seems such a waste.
There's no 125mph authorised lines north of Edinburgh and Glasgow, so no, they don't run at 125mph.Just wondered, fastest they run on my local line (Dyce to Aberdeen) is 75mph.... and that's only for probably 3 or 4 miles. Seems such a waste.
The shorter carriage sets aren't permitted to run at 125 mph anyway as they have insufficient brake force. I don't necessarily view it as a waste - yes, they're now working in a role where their full capability isn't required, but it doesn't minimise the fact that in their previous roles that high-speed capability was relied upon for many years.Just wondered, fastest they run on my local line (Dyce to Aberdeen) is 75mph.... and that's only for probably 3 or 4 miles. Seems such a waste.
Are you sure that they are not able to run at 125 MPH. I believe the power cars are braked to the same rate as the trailer cars. I remember when recommissioning tests took place after major overhauls two power cars ran at 125 MPH.The shorter carriage sets aren't permitted to run at 125 mph anyway as they have insufficient brake force. I don't necessarily view it as a waste - yes, they're now working in a role where their full capability isn't required, but it doesn't minimise the fact that in their previous roles that high-speed capability was relied upon for many years.
FGW modified their power cars to have a reduced braking force (similar to the original two-stage configuration) as they found that the Castle set power cars were doing a lot more of the braking than the trailers were. The modification evened out the braking levels and thus resolved the problem they were having with brake-block wear on the power cars. ScotRail inherited GW's power cars and to the best of my knowledge haven't undone the modification since there's nowhere they can hit 125 mph anyway.Are you sure that they are not able to run at 125 MPH. I believe the power cars are braked to the same rate as the trailer cars. I remember when recommissioning tests took place after major overhauls two power cars ran at 125 MPH.
If the ScotRail power cars have the lower brake force and are the same as they were when with Great Western, then the Castle set point is an irrelevance, as the mod must have been done by FGW/GWR pre-Castle introduction.FGW modified their power cars to have a reduced braking force (similar to the original two-stage configuration) as they found that the Castle set power cars were doing a lot more of the braking than the trailers were. The modification evened out the braking levels and thus resolved the problem they were having with brake-block wear on the power cars. ScotRail inherited GW's power cars and to the best of my knowledge haven't undone the modification since there's nowhere they can hit 125 mph anyway.
Surely then if the power cars brake at the same rate as the trailer cars, the number of trailer vehicles will not affect the train braking rate. The short formation HSTs will then still be able to run at 125 MPH.FGW modified their power cars to have a reduced braking force (similar to the original two-stage configuration) as they found that the Castle set power cars were doing a lot more of the braking than the trailers were. The modification evened out the braking levels and thus resolved the problem they were having with brake-block wear on the power cars. ScotRail inherited GW's power cars and to the best of my knowledge haven't undone the modification since there's nowhere they can hit 125 mph anyway.
I'm not 100% sure about it, but when they came north weren't they timetabled at 125mph?FGW modified their power cars to have a reduced braking force (similar to the original two-stage configuration) as they found that the Castle set power cars were doing a lot more of the braking than the trailers were. The modification evened out the braking levels and thus resolved the problem they were having with brake-block wear on the power cars. ScotRail inherited GW's power cars and to the best of my knowledge haven't undone the modification since there's nowhere they can hit 125 mph anyway.
Post original two-stage brake set-up, yes. But as mentioned FGW had its power cars modified to restrict their braking effort as the nature of how the brakes apply on HSTs meant that repeated light applications resulted in excessive brake pad wear on power cars as they were doing most of the initial braking effort.Surely then if the power cars brake at the same rate as the trailer cars, the number of trailer vehicles will not affect the train braking rate. The short formation HSTs will then still be able to run at 125 MPH.
Yes, but does that definitely mean they ran at 125mph?I'm not 100% sure about it, but when they came north weren't they timetabled at 125mph?
As is on the stretch out of Haymarket heading Westwards. It's certainly 385 rivalling!No, but the acceleration coming off the forth bridge past EDI airport is seriously impressive.
Shame they didn't regear them for 100mph as would have given better acceleration.The shorter carriage sets aren't permitted to run at 125 mph anyway as they have insufficient brake force. I don't necessarily view it as a waste - yes, they're now working in a role where their full capability isn't required, but it doesn't minimise the fact that in their previous roles that high-speed capability was relied upon for many years.
I don't think it's necessary for the cost that would've incurred. They take off like greased lightening as it is!Shame they didn't regear them for 100mph as would have given better acceleration.
My original point still applies. If all vehicles in the train brake at the same rate then the number of vehicles is irrelevant. Short formed trains will stop in the same distance as longer sets so they will all be capable of braking from 125 MPH.Post original two-stage brake set-up, yes. But as mentioned FGW had its power cars modified to restrict their braking effort as the nature of how the brakes apply on HSTs meant that repeated light applications resulted in excessive brake pad wear on power cars as they were doing most of the initial braking effort.
I haven't read of other TOCs being affected though.
ScotRail's safety case is only for 100mph.
Yes, but my point is that this doesn't apply for ex-FGW sets as the power cars do not brake at the same rate as trailers. Not in the same way as the original HST set up with the two-stage brake but enough that GWR restrict 3-car Castle sets to 90mph for instance.My original point still applies. If all vehicles in the train brake at the same rate then the number of vehicles is irrelevant. Short formed trains will stop in the same distance as longer sets so they will all be capable of braking from 125 MPH.
The fact that an operator limits their stock to a given speed doesn't necessarily mean that the stock cannot travel faster. Perhaps they've limited their sets to 90mph because it's fast enough to deliver the timetable and saves fuel/wear and tear.Not in the same way as the original HST set up with the two-stage brake but enough that GWR restrict 3-car Castle sets to 90mph for instance.
East Midlands ran a 2+4 set at 125mph.Post original two-stage brake set-up, yes. But as mentioned FGW had its power cars modified to restrict their braking effort as the nature of how the brakes apply on HSTs meant that repeated light applications resulted in excessive brake pad wear on power cars as they were doing most of the initial braking effort.
I haven't heard that distinction between braking steps mentioned but that would make much more sense than an outright restriction of brakeforce. I was informed the restriction was to 3 bar max on power cars but presumably that applies below full service then?I understand that the modification to the power car braking only applied to braking steps below Full Service and that the Full Service brake force was not affected. As the Railway Group Standards performance requirements only apply to stopping distances in Full Service, and the modification didn’t reduce these, the max speed of short formed sets should not be affected.
90 for 3 trailers. 0-2 trailers is 75mph, 4 trailers is 100 and 5 125mph according to GWR instructions that a GWR driver of Case sets was good enough to explain on another forum.The fact that an operator limits their stock to a given speed doesn't necessarily mean that the stock cannot travel faster. Perhaps they've limited their sets to 90mph because it's fast enough to deliver the timetable and saves fuel/wear and tear.
Yeah the Castle bit shouldn't have crept in there.If the ScotRail power cars have the lower brake force and are the same as they were when with Great Western, then the Castle set point is an irrelevance, as the mod must have been done by FGW/GWR pre-Castle introduction.
My information came from the retired InterCity Brake engineer.I haven't heard that distinction between braking steps mentioned but that would make much more sense than an outright restriction of brakeforce. I was informed the restriction was to 3 bar max on power cars but presumably that applies below full service then?
It was a former BR brake engineer who explained the original set-up, revised set-up and FGW set-up to me, but he is retired I understand and only had the details of the FGW modification second hand.
So did mine, the gentleman I posed my questions to in relation to a previous thread on a similar subject of HST braking I came across while searching for information via Google. The search at the time turned up some posts on another forum to this one relating to speed restrictions on short-formed HST sets and how that after the brake modifications there was no need to speed restrict sets with fewer than five trailers as the power cars were now full braked throughout the speed range.My information came from the retired InterCity Brake engineer.
Indeed but EMT/EMR aren't FGWEast Midlands ran a 2+4 set at 125mph.
In what way is 75/100mph ”a waste”?Just wondered, fastest they run on my local line (Dyce to Aberdeen) is 75mph.... and that's only for probably 3 or 4 miles. Seems such a waste.
In fact i now see that I had overlooked a conversation I had with another member if this forum on this subject. In their reply they do indeed state that the restriction was only to light applications and the 4.1bar full service pressure remained unaffected by the mods.My information came from the retired InterCity Brake engineer.
There are other reasons for restricting the speed of short formation trains than purely brake performance. For example, fewer vehicles means a brake defect on one vehicle will have a greater effect on the braking performance of the train.
Really, I never knew that!Indeed but EMT/EMR aren't FGW
I think you are correct. Although drivers understand the different braking performance of the various traction they sign, minimising the effect of different train formations is good practice. Also short form HST sets are unlikely to be operating on routes requiring significant high speed running.In fact i now see that I had overlooked a conversation I had with another member if this forum on this subject. In their reply they do indeed state that the restriction was only to light applications and the 4.1bar full service pressure remained unaffected by the mods.
So, really there is indeed nothing to prevent safe use of a short set at 125, except that defensive driving policies may mean that because of the reduced brakeforce in low brake settings, the need for those speed restrictions comes in because the braking distances could only be met with a full service application?
Could that be the reason for the GWR restrictions?
The 385's do 0-60mph in around 44 secs compared to around 64 secs for a 2+4 HST. But the 60mph to 90mph time shows the HST's superiority once rolling - 50 seconds vs 60 secs for the 385. I measured 0 to 99mph in around 2.5 mins for both. What's interesting here is the Class 385's superior start gives it around a 20 second advantage from rest to 2.5 miles over the HST. Both limited to 100mph though! One of the issues for the HST is the slow releasing brakes compared to a unit, and the fact drivers can't give them full power from a start.As is on the stretch out of Haymarket heading Westwards. It's certainly 385 rivalling!
