Scotrail HSTs - 4-5 years in
ld0595
1 Aug 2014
Now that we're in August, is there any indication that ASLEF still intend to instruct their drivers not to drive HSTs later this month?
John Bishop
15 Nov 2018
Perth
We haven’t heard a peep after the last update early July. The deadline is a week Saturday.
92002
27 Mar 2014
Clydebank
Considering they have been safely in use for the last 50 years it would appear to be a case they may lose if the courts have to decide.
Moderator note: safety discussion continues at:
BRX
20 Oct 2008
I was on 1B84, the 1356 Aberdeen - Edinburgh, yesterday and the guard said that the set would have to be withdrawn on reaching Edinburgh because some of the toilets were unusable because their retention tanks were full.
This is probably isn't a rare event on the higher mileage diagrams, and I assume that it will be classed as an in service failure even though after a brief visit to the depot the set will be ready to go again.
It did make me wonder how much irratating shortcomings like this, which aren't really faults, have reduced the overall availability of the HSTs or the percentage of completed daily diagrams.
On longer distance diagrams is this problem unique to HSTs where space available in which to fit a tank had obviously governed its capacity?
For example, does a 156 going from Glasgow to Mallaig and back in the tourist season need a "toilet break"?
If it was happening regularly - then that would me more like a fault in the diagram planning, rather than a fault in the train.
Like you, I'm also curious about what the faults are that cause the HSTs to get pulled from service, or to be unavailable for their planned diagrams. Whether it's mainly a constellation of "small" things or not.
InOban
12 Mar 2017
I came across a tweet showing that HA12 is back in service after a number of years out of action.
hexagon789
2 Sep 2016
It was indeed.
Power cars - 43129 and 43037
Workings were - 1B70, 1A81 &1T50
Sunday 6th August
HA06 was doing 2+5 platform length testing at Inverness this afternoon in-between arrival from and returning to Glasgow.
The exile
31 Mar 2010
Somerset
If the Scotrail sets have had as many removed /locked out as their GWR counterparts have done, then it’s not surprising that the remaining ones can’t cope.
20 Mar 2012
So today is meant to be the last day of HSTs according to ASLEF but no news so far whether the HSTs be withdrawn or will continue in service from tomorrow for the foreseeable future
chuff chuff
25 Sep 2018
Was put out a couple of weeks ago that the date had been put back a week ago or two as it thought it would be insensitive to go on the anniversary.
Davester50
22 Feb 2021
Are ScotRail paying the leases for the extra converted 5th cars that have languished in sidings for the last year or so?
Goldromans
11 Feb 2017
Is there a plan underway then for getting 2+5's in to Platforms 3 and 4 at Inverness? I know it's been discussed for a while know but didn't realise a solution had been decided on? Great news if so.
hexagon789
2 Sep 2016
It seems as though though may well be, there have been a couple of clearance test runs recently - so must be for something. They've all been with 2+5 sets.
John Bishop
15 Nov 2018
Perth
Platforms 3 and 4 are now cleared for 5+2 HSTs. Whether we get any more sets made up to 5 car is another question, but given the loadings on the HML these days, it needs to be done as a matter of urgency.
Goldromans
11 Feb 2017
How did they get round the platform length issue? Great to hear though. It will definitely be interesting to see how many more 5-car sets appear, as I believe ScotRail's excuse had been difficulty diagraming them because of capacity at Inverness? Doesn't really fly anymore if that's no longer a problem.
John Bishop
15 Nov 2018
Perth
Added Car stop marker boards closer to the buffer ends and installed new, lower LED signals at the end of P3 and 4. They always did fit on but it was the signal sighting which was the issue.
BRX
20 Oct 2008
The other silliness at Inverness (if I remember it right) is that the whole of platform 1 or 2 is occupied for the bulk of the day by the sleeper stock, because there's not anywhere else with a functioning suitable shore supply. Perhaps the technical wizardry that has made it possible to install some signs and new signals on p3/4 can also be employed to solve this issue.
Stathern Jc
30 Nov 2019
Inverness
Thanks for that info.
Sounds oh so simple when you say it there compared with the earlier suggestions that changes to the signal positions would be necessary.
There could have been misinterpretations that it was the siting that needed to be changed when it could have been the height all along, but the significant costs that were referred to seem to make a height adjustment less likely to have been the plan?
InvHst
9 Dec 2018
Sleeper used to use 1 all day. But the shore supply been broken for absolute ages so the sleeper now uses 2 all day
fgwrich
15 Apr 2009
Hampshire
I’m surprised it isn’t shunted out to the depot and plugged into the ERS EGV Mk3 that’s up there. I mean, that’s what it came up at Christmas for!
JModulo
17 Nov 2013
67A
Thats actually for when its usually sat for a few days, ie over Christmas etc to prevent the stock freezing.
BRX
20 Oct 2008
Is there something especially technically difficult about just installing a shore supply, where that generator coach is? Or somewhere else, that isn't a station platform?
It seems very bizarre to me that given the problem of a station with limited capacity to accommodate longer trains, the apparently easier solution is to re-engineer shorter platforms, rather than release an already plenty-long-enough platform from its role as a siding.
Killingworth
30 May 2018
Sheffield
Given how much was invested in these trains it certainly seems odd that the apparently obvious inability to operate 5 car trains to Inverness wasn't realised and so easily resolved 4 years ago.
hexagon789
2 Sep 2016
I thought that it was the whole reason for the mix of four and five-car sets originally - therefore, it would have been known about?
