ScotRail December 2018 Timetable change
fairliered
11 Sep 2011
Ayrshire
Does anyone know whether the through Ayr to Edinburgh services will be 380s, 385s or will no longer run through.
route101
16 May 2010
From what ive read just the Cathcart Circle for 385s ? Intially im sure it was the Newton and Neilston branches .
The 385s have been testing on the Inverclyde , so maybe a chance of one in service .
Chrism20
27 Feb 2013
Still a good few cancellations which should hopefully start to clear off as the training completes, however the one big positive is that there were twelve Edinburgh bound movements over Newbridge this morning between 0659 and 0758 and the service doesn’t seem to have fallen to bits. There was one cancelled service which if it had ran it would have passed through easily making it thirteen within the hour.
So that hopefully should answer one of the questions that has continued to be repeated over the last few months - yes Newbridge can cope with the planned movements.
InOban
12 Mar 2017
Surely it's movements outbound from Edinburgh which are going to run into conflicts at Haymarket and Newbridge?
Chrism20
27 Feb 2013
At approximately the same time (0702 to 0801) there were twelve went the opposite way with one cancelled.
Newbridge was the pinch point that certain people kept bringing up that had the potential for problems. If everything runs to plan (ideal world I know) there is no problem with the planned movements at Newbridge.
I agree Haymarket has more potential to screw it but it has very rarely been mentioned as the potential problem here.
mcmad
11 Mar 2015
Think you're missing the point Chris. Of course the plan works if everything is perfect but its the chain reaction if one train is even a couple of minutes late that was the concern. We'll see what happens when it happens.
Chrism20
27 Feb 2013
My point was that it has been implied on numerous occasions that regardless of the timetable Newbridge would go to hell in a handcart.
If there is disruption of course there are going to be problems but the timetable does work which is my point.
Stopper
11 Nov 2017
The point was never made that Newbridge Junction would struggle in normal timetable. The point was that it struggles with 10-11tph when one thing goes wrong which results in a chain reaction. Using one day of nothing going wrong to prove that Newbridge can cope is bizarre. The first time there is disruption I still worry about Newbridge.
Chrism20
27 Feb 2013
Oh so it wasn’t you who said “Newbridge Junction is going to be mayhem come December”?
jopsuk
13 May 2008
I saw this and similar ones on RTT
http://www.realtimetrains.co.uk/train/G80046/2018/12/10/advanced
Anyone know why it’s saying Kilmarnock to East Kilbride when it’s clearly a Kilmarnock to Central service?
is it displayed at stations as a through service to East Kilbride? Because it clearly states that it joins with another train to depart to EKL from Central
Edit: I looked at National Rail station departures- the services are indeed advertised as through services to East Kilbride
Starmill
18 May 2012
Bolton
This could be said of pretty much the majority of the mainline railway though, to some degree or another. It's true at Portobello Jn, Haymarket East Jn, Bridge Street Jn and at Marshgate Jn, Slade Lane Jn, it is definitely true at Castlefield Jn and Ordsall Lane Jn, and it's a serious problem at Windmill Bridge and Gloucester Road Jns, and at Woking Jn. It is a problem at Herne Hill Jns, at Proof House Jn, and at Woolmer Green Jn. Many of these problems are rather worse and cater to more movements than Newbridge Jn does. Is that a reason not to run trains?
Altnabreac
20 Apr 2013
Salt & Vinegar
You can say that the Dunblane peak (7-8am) service being “thirded” is dramatic, but it’s true. One service has been moved to an earlier, less convenient time, and another has disappeared.
The reason that there is possibly going to be a Edinburgh-Dunblane/Alloa split on that service (which I believe isn’t the only one) is because there are no extra paths to run the usual Alloa service because they have been replaced with ultra-pointless Cumbernauld services!
Newbride Junction is going to be mayhem come December.
Airdrie did not have another, better station serving it towards Edinburgh already, as Cumbernauld does. The Glasgow flows from Cumbernauld are not even that big as it is. The main problem (which is being ignored by most) is the extra 2tph through Newbridge Junction. That’s 12tph (possibly more) at peak times. I know electrics will help the situation, but it heavily struggles with 10tph as it is.
Linlithgow losing Stirling links & only remaining 4tph to Edinburgh is the biggest disappointment to passengers, from what I’ve been hearing at the station.
I think the main gripes are that Linlithgow & Polmont are getting minimal benefit (with some reduction) whilst stations like Camelon & Larbert are getting huge increases.
Also adding that there will be another 2tph through Newbridge Junction, which struggles heavily with 10tph as it is.
Currently there are several units held every morning at Newbridge Junction. I have no reason to believe it will be absolutely fine after adding another 2tph. To suggest that I don’t have a clue for implying that the ‘lowest priority’ services of 12tph will be held at a nightmare of a junction quite frankly says it all about your argument IMO.
Seems you can’t complain on here without being aggressively shut down with no valid reason. I am not the only one that is opposed to this timetable change. I want the best timetable possible and we aren’t being given that, but unfortunately we’ll just have to live with it as I have said before. The car is becoming a much more attractive option.
Until the Almond chord is built (which I fully support), was there any need to add an extra 2tph through Newbridge knowing the problems it may (almost certainly will) cause?
Funnily you forgot to say it was only “during disruption” that Newbridge Junction wouldn’t cope in each of these posts...
hexagon789
2 Sep 2016
Even though it's just that the service goes on to form an EK service after arriving at Glasgow Central? Seems a bit strange.
Mind you I suppose the Edinburgh-Ayr services are in a similar vein.
Stopper
11 Nov 2017
Forgot we were in a country where trains ran on time and absolutely perfectly every single time....
Trains WERE held most mornings due to late running services (from Milngavie mainly) when the frequency was 10tph. I see no reason why 12tph changes that. Thankfully it no longer affects my commute.
route101
16 May 2010
Strange to advertise that as through service . Arent some EK services linked with via Shotts 156s too >
hexagon789
2 Sep 2016
Possibly, not really sure. From what I remember am incoming EK forms an outgoing Kilmarnock and vice-versa. For the Shotts line an incoming semi-fast forms an outgoing stopper.
I has thought that was always the case apart from peak-time perhaps, but I could very easily be wrong and certain Shotts line services swap units with the EK services.
The incoming Barrheads I believe generally go on to form outgoing Barrheads if I remember rightly.
Gadget88
23 Aug 2013
Can someone explain why on the way to Edinburgh it skips Linlithgow but at night on the way back it stops at Linlithgow and Polmont?
Gadget88
23 Aug 2013
Poorly timetabled too as tonight it sat ages in Camelon and Falkirk this never happened under the old timetable only ever sat at camelon on the way to Edinburgh.
InOban
12 Mar 2017
Are you referring to the Dunblane trains? In the evening, the E-G goes half hourly and the Cumbernauld trajns terminate at Grahamston. The Dunblane trains become all stations.
gsnedders
6 Sep 2015
The change of the ex-Inverurie, now Aberdeen–Glasgow service, to depart Perth a minute earlier has been getting some press given it makes it an on-peak service. Per the WTT, the change seems to be a decrease in booked time at both Stonehaven and Carnoustie by 30s, thereby making it a minute earlier by Perth.
route101
16 May 2010
Might of changed , remember coming off a Shotts 156 and back on it for EK service . Now there would be a risk of 158 going onto a EK service though this was only a few years i recall .
hexagon789
2 Sep 2016
Perhaps they used to, but stopped after 158s started operating on the Shotts line? I can remember Whifflet being mainly 158s, with Shotts 156s pre-electrification and adding into the Low Level services.
fairliered
11 Sep 2011
Ayrshire
Have on several occasions used the 1549 Edinburgh to Glasgow Central via Carstairs to connect with the 1723 Glasgow Central to Largs, before realising it’s the same unit travelling through. The fact that the 1723 leaves from platform 6 whereas all other Largs trains leave from platforms 10 to 15 should be a clue!
