Scariest Thing You Do As A Driver
TDK
19 Apr 2008
Crewe
A 67 engine room door at the air end opening when under full load tends to suck everything loose into the engine room including jacket, HV vest and anything else not tied down, that can be a bit of a shock.
scotraildriver
15 Jun 2009
LOL Been there done that.................... 67004 I hate u
Clip
28 Jun 2010
Close calls with people on crossings (if people spent any amount of time in a driving cab they would be shocked at how frequantly this happens).
I know it happens a lot but I was in the cab just the other day and saw it first hand. I nearly sh*t myself. Driver just looked at me shrugged his shoulders and laughed. This is why Clip doesnt like going in the drivers cab.
6Gman
1 May 2012
To lighten the tone from all the gore and to offer tedious/ uncomfortable experiences .....
My father used to mention:-
Booking on at 11pm, taking a Class 8 freight to Lostock Hall and then having to sit for 4 hours in a tiny messroom until the first bus into Preston.
A Class 40 failing halfway up Shap in a blizzard and having to walk to the signal box.
scotraildriver
15 Jun 2009
A maintenance engineer is supposed to be in the engine room while the engine is running and when his/her duties require, a driver is not and most certainly not while using it as a corridor to save leaving by the cab door, either that or I've been fed an awful lot of BS in the past
We shunt the sleepers at Edinburgh and are required to change ends on the loco in a limited clearance tunnel several times. Therefore no option to go outside. I've never been comfortable doing it but it does seem to be the accepted practice.
bronzeonion
1 Apr 2009
West London
I know it's 'only in pres' but going in the engine room whilst engine is running is really not that bad and this includes a 47 which as some will know is very tight for room.
barbarajohn
18 Feb 2014
st helens
i saw it comming! (the breezeblock i mean!) from the vandals throw, swoooooom BANG!,,showered with glass, blinded , shocked, shivering like an M P with his pants round his ankles, i rolled drunkedly out off the cab at liverpool lime st. The station inspector never even looked at me, "OH," he said , " this unit will have to come off!
GB
16 Nov 2008
Somewhere
Are DB (or other freight company) drivers issued with ear protection by the company?
If not, then I imagine that is the difference. If an employee is required to work in a noisy enviroment, the company has a responsibility to limit the risks as far as is reasonably possible.
All GBRf traincrew are issued with ear plugs for when in the engine room. Like someone else said, spending 30 seconds in there to change ends is not an issue and often offers less risk then changing ends on the ground.
scotraildriver
15 Jun 2009
Indeed. Its not even that noisy, I just don't like the atmosphere. Smells good mind u!!! Nice and oily.
91104
21 Jun 2013
Having your windscreen smashed while going along at 125 was a bit unnerving to say the least.
A-driver
9 May 2011
Now that isn't 'smashed', it's just 'shattered'. Or at least that is what my control told me when my 365 windscreen looked like that after a triple bird strike at 100 mph a few years back. I was told I could carry on as it wouldn't shatter in on me. Funnily enough I wasn't quite as confident as them and didn't really want to risk a glass shower.
Should add that I told them to stuff it, ran wrong road to the previous station, kicked everyone off and crossed over onto the right road and ran into the closest depot!
7 Jan 2010
I don't blame you at all A-driver. Not just for not wanting the glass cave in on you but what about the impaired vision? I'm sure control would have been the first ones to jump on you if you has SPAD'd because of it.
On a side note, a few years back, we had a broken windscreen changed out on a 180. I took a sledge hammer to the broken windscreen and even with about 30 blows i still couldn't penetrate the glass. The polycarbonate inner laminate really is amazingly strong.
But i certainly wouldn't want to keep a train in service with a screen damaged to that extent.
#1 driver
2 May 2013
england , top right
we ( DBS ) get -
for use while driving , if you get a noisy loco .
