Sandite
RJ21
24 Apr 2016
Stupid slightly technical question, does hot sandite have a slightly gunpowdery smell? On a 142 following a NR MPV which was spraying the railheads. Under braking there is a very distinct smell similar to some of the powdered metals used in fireworks, or even cutting discs. First thought was the brakes toasting themselves but I am wondering what residue from spraying would do.
scott118
24 Feb 2015
East Anglia
would it not be a different brake block material perhaps, that you are smelling, rather than sandite? New blocks give off different odours, compared to a 'bedded in' set..
RJ21
24 Apr 2016
Could be, though the smell wasn't apparent arriving at Manchester Picc, when we were no longer following the RHTT, one of those odd things some of us notice I guess.
Nym
2 Mar 2007
Somewhere, not in London
Certain metal compounds similar to that used in fireworks can be added to increase the conspicuity of the sandite dispensed. making it appear white for example.
RJ21
24 Apr 2016
That may explain it, I'd never noticed the smell before which is what made me think of what had passed the station immediately ahead of the 142 I got on, and their brakes work on the outer diameter of the wheel which would heat any residue which had been picked up.
