Annetts key
I’m no expert. But here’s my take.Same fate befell the Sheffield in the South Atlantic though I don't recall onboard munitions exploding as having been a factor. Just a very big hole after fire enlarged the initial missile damage. Can any "expert" here make a comparison between the Exocet missile of that era with today's Neptun or similar anti-ship missiles?
Fire on board any ship, especially warships can be extremely damaging.
There were numerous failings that contributed to HMS Sheffield’s loss. After the missile hit, the biggest factor was the resulting fire. The crew has difficulty trying to control this, as the ships firefighting system was damaged by the missile. The fire itself did not cause the ship to sink. It sank due to taking on water after being towed, the water entering via the hole caused by the missile.
It’s likely that the Russian ship was not expecting a missile strike. Two missiles were apparently launched, but we don’t know if both hit the ship.
If a missile hits a ship, the ship can suffer damage due to the impact, due to the warhead exploding, due to the resulting fire, and due to internal systems being damaged. Any of the above may result in secondary explosions if fuel, ammunition, missiles or other ordnance is damaged or is triggered by the heat from fires.
What happens next very much depends on where in the ship the damage has occurred and how effective (or not) the firefighting is.
If the fires can be put out, and the hole(s) caused by the missile(s) can be patched up and made watertight, the ship may be able to be towed to the nearest available friendly port. Or if the damage to the propulsion systems is not too bad, it may be able to proceed under its own power.
But if the damage is too extensive it may not be considered worth trying to save. If water enters through the hole(s), which is more likely if the ship is attempted to be moved or if the sea conditions are poor, then the risk of sinking increases significantly. Especially if no attempt has been made to patch the holes or it’s ineffective.
More recent analysis has concluded that the warhead did explode. See the Wikipedia articleOn the subject of the Sheffield, I once read that the Exocet warhead didn’t actually detonate on impact and became detached, and that it was the “body” of the missile that penetrated the hull through pure kinetic energy. Can anybody confirm if this is actually true?
In 2015, a MOD re-assessment of the attack concluded that the Exocet warhead did indeed detonate inside Sheffield, with the results supported by analysis using modern damage analysis tools not available in 1982 and evidence from weapon hits and trials conducted since the end of the Falklands campaign.
