Rural signals
Trains1
7 Aug 2024
Manchester
Hello does anyone know where I can find a map of rural signals I have looked on OTT but can't see them
Thanks
greatkingrat
20 Jan 2011
Many of the more rural lines have older signalling systems that do not provide the necessary information to allow live maps to be produced.
The exile
31 Mar 2010
Somerset
There are several threads on mechanical signalling, which probably give you what you’re after.
DennisM
3 Apr 2016
Thanks
I believe flashing your headlights is one rural signal, although I’m unsure of the meaning :oops:
12LDA28C
14 Oct 2022
Thinking about it I was thinking like branch lines that haven't yet been computer controlled
What exactly do you want to see? Physical maps showing the location of signals in rural locations nationwide? TOCs / FOCs and NR will have such maps but they are not for public consumption.
12LDA28C
14 Oct 2022
That's what I was thinking is there a way get a diagram of them?
If you're replying to me then as I suggested, they are not for public consumption and even if they were you won't find them all on one 'diagram', each route will have it's own map. I'm sure you can appreciate that will be a lot of maps for all 'rural' lines nationwide, once you determine exactly what a 'rural' line is, whether you mean semaphore signals, remote lines away from major centres of population or whatever.
takno
Verified Rep - Traksy
There isn't any central source which is publicly available.
If you just want to know what trackwork and signal boxes exist in an area then you can get that information from the Sectional Appendices on the Network Rail website (or probably from Quail track diagrams - I've never actually looked at those so I'm not sure what information is on them).
If you want to know what signals exist, then for the most part the information just isn't all that useful or interesting without a live feed. If there is something you specifically want to find out you may be able to find photos including the box diagrams for some of the hundreds of boxes at photos.signalling.org, and various other places such as llangollen_signalman on flickr.
Freightmaster
Verified Rep
7 Jul 2009
mainly the mid-Cheshire line from Northenden to Chester
If you want to know the location of the signals on lines like that, a 'drivers eye view' video
can be a great resource. I highly recommend Don Coffey's channel in particular:
Here is his video covering the Chester to Northenden route:
(it takes a bit of practice, but you can read off individual signal numbers if you pause
the video at just the right time)
MARK
JN114
28 Jun 2005
The Mid-Cheshire line is covered in SimSig
In the simulation manual is a diagram of signal numbers that should satisfy up to a “casual interest” level of detail.
Magdalia
1 Jan 2022
The Fens
Most manual signal boxes have diagrams usually displayed above the lever frame.
Pictures of these can sometimes be found on flickr, for example, Northenden Junction here:
Northenden Junction box diagram​
One of the older style diagrams still around, with evidence of past infrastructure erasings by the S&T following alterations. The line to Edgeley No.1 is worked by Acceptance Levers and the lights in the top left of the diagram indicate whether a train has been accepted at either Edgeley or Northenden.
Still to be removed from the current set up are the now disconnected Blue Circle cement sidings ("Station Sidings Ground Frame") and reference to lever no.15 (and the little detonator insignia) that used to indicate the location of the box detonator placers.
August 2021.​
