Running out of sand
westcoaster
4 Dec 2006
DTOS A or B
Maybe it has more to do with unit type?
I saw a couple of 465/466 and 375/377 going the other way that didn't appear to be having any difficulty at all...
Give me a 465 over a 319 anyday. (and a 375 over both).
Give me a 319 all day long over 377's. I'll try and answer as much as I can. 319's use smart sanders which will work in all brake steps and can be manually applied while taking power. Sand hoppers are located on 3/4 coaches.
High Dyke
1 Jan 2013
Yellabelly Country
So now that I can use the PC I've found the following information
The original train was 2E65
http://www.realtimetrains.co.uk/train/W44352/2013/12/06/advanced
It terminated at bellingham 23 mins late at 0840.
5 minutes later 5E65 was scheduled to start from Bellingham for Criklewood Depot
http://www.realtimetrains.co.uk/train/O44764/2013/12/06/advanced
It actually left 9 minutes after that
Given the similarity of the numbers I assume that this is the now empty train heading to the depot.
Also it looks like some of the fast trains that ought to have been behind us were re-routed via the CML.
Am I close or should I give up?
That's bang on. The train did run as 5E65 from Bellingham - Cricklewood Depot.
I couldn't find any relevant infirmation about sanding equipment in the rule book, but did find this on the Railway Group Standards (RGS) website.
http://www.rgsonline.co.uk/Railway_...ck/Railway Group Standards/GMRT2461 Iss 1.pdf
Sanding Equipment Fitted to Multiple Units and On-Track Machines
Of course in reality the leaves don't stop falling at 23:59:59 on November the 30th, but those in offices who make the decisions believe that they do...
No we don't. We believe the leaves stop falling when there's none left on the trees, and plan accordingly.
One complication is that the treatment trains deployed south of the river have to go off to be refitted for winter; a careful balancing act required when autumn and winter overlap.
A-driver
9 May 2011
Well the treatment trains stopped on the GN, they appeared again yesterday after Thursday.
talltim
17 Jan 2010
OK, what decision would you make if it was down to you, given the timetable for the RHTT has to be prepared months in advance?
I would make the decision that the timetable for the RHTT doesn't have to prepared months in advance
455driver
10 May 2010
So how are you going to reconfiger the trains for de-icing then?
They got caught out last year because the frost followed immediately after leaf fall, the result was there was only one de-icing train available and we were sparking all over the network.
There has to be timetable otherwise the train wont be correctly configured, neither will the appropriate staff be in place.
