Hi,
Does a class 20 run cab first or bonnet first?
Thanks
Hi,
Thanks
Does anybody know why they were designed with the single cab? Was it just to improve driver acceptance at the time of converting to diesel from steam? Besides shunters, they're a bit of an anomaly.
money, weight, money.
back in the day they were not such an anomaly - see the D82xx, D84xx etc.
No...Did the 20s ever have a reduced maximum speed when running bonnet end first?
It was and is, an established American style. Their version would have a cab higher than the rest of the bodywork.
Why would that be?
91s have a restriction when blunt-end-first, so it's a reasonable query.
Both ends of a Class 20 are rather blunt, if either end was going to have a restriction surely it would be the cab as that's a greater surface area.
Other way round with a 20, surely, as the issue is visibility from the cab.
That's because of the aerodynamics of the pantograph's knuckle creating excessive uplift force on the OLE, limiting speed to 110mph - neither issue will trouble a 20!![]()
I remember reading or hearing many years ago that ex-steam drivers, used to a large lump of loco in front of their cab, felt vulnerable in diesels with only some sheet metal and glass as protection from any obstruction on the line, and so felt happier in a class 20 or similar running bonnet forward. The photos that I have seen suggest that it was much more common in the early days than it was after diesels became established.
Seeing as they are 60 years old this year does anyone know if there are going to be any "official" events celebrating that? I guess some preserved railways will but NR?
In recent years I don't remember any events on the national network to celebrate anniversaries of introduction of particular classes, other than the HSTs, which are a special case.Seeing as they are 60 years old this year does anyone know if there are going to be any "official" events celebrating that? I guess some preserved railways will but NR?
Sorry if this is a dumb question, but How does that not have the same effect when the 91 is propelling as surely the knuckle of the pantograph is still under the same force?
No, in one direction the airflow produces a downward force on one half of the pantograph arm and an upward force on the other half. When running in the other direction these forces are reversed, so the forces operating on the various parts of the pantograph are different in each direction.
But the pantograph would be the same way around and under the same forces if running blunt first as if propelling - but there is no speed restriction on a propelling 91
