scousethomas
- Joined
- 8 Sep 2013
- Messages
- 5
Anyone able to put section 4.6 of the above mentioned module into plain english or know of a website which explains all the sections?
Thanks
Thanks
Reds at the front I can understand, but why no lights at the rear? What if the train has failed and requires assistance from the rear?
Having re-read it, I can see the point about switching off all lights on the rear of the train being confusing. I'd assumed you would have some form of light on the rear of the train but apparently not according to the above? :?TW1 said:4.6 Lights when detained on a running line which is used by trains travelling in the opposite direction
If your train is crossed over to a line on which trains run in the
opposite direction and the movement is then detained, you must
during darkness, fog or falling snow or if in a tunnel, make sure
that you:
switch on the tail lamp at the front of the train
have switched off all other lights at the front and rear of the
train.
You do not need to carry out this instruction if the line on which
you are detained is bi-directional
Absolutely, which is why i'd assumed until I re-read the above, that you would in effect be showing tail lights at both ends. but the bit below doesn't read like that to me:Headlights and marker lights are only required at the front of the train and are therefore an indication that the train is headed that way, and thus would also be confusing if the head/marker lights were lit at, what is perceived to be, the rear.
TW1 said: switch on the tail lamp at the front of the train
train.
