Rugby station, exit from platform 2 location
LUL1970
21 Jul 2014
Good Afternoon,
I may be travelling on a late night Avanti service from Euston and will have to change at Rugby for a RRB to Birmingham New Street. Can anyone recommend which would be the closest carriage of an 11 car Pendolino to the exit from platform 2 for a head start in the rush to the replacement bus.
Thanks in advance
LRV3004
17 Mar 2015
Good Afternoon,
Thanks in advance
I’d say around the part where it changes from first to standard class.
Andy Pacer
11 Jul 2017
Leicestershire
Good Afternoon,
Thanks in advance
As mentioned if youre on a 11 car then being in unreserved coaches G or U should put you almost in pole position.
LRV3004
17 Mar 2015
Am on Rugby station platform 2 right now! The circular spot with “3” on it is nearest to the ramp down to the bottom! Front of Coach G on a 9-car, back of Coach F on an 11-car should do it!
Also took this, if it helps!!!!
LUL1970
21 Jul 2014
Thank you
louis97
14 May 2008
Derby
This doesn't match the photos of the poster you attached, a 9 car doesn't have a coach G for a start.
Back of coach G on a 11 car and back of Coach J on a 9 car according to the poster. Making special note of the two diagrams for a 9 car dependent on which way you are travelling.
