Routing Guide Query Maps
headshot119
31 Dec 2010
Dubai
Just a quick one to run by everyone.
Wrexham General - Stoke On Trent Anytime Day Return with railcard £9.90
I know it's valid via Crewe, however is it also valid via Liverpool?
Looking at the routing guide I need maps CH + EM both which have Liverpool and Hunts Cross as routing points.
Not sure if I've read it right though.
EDIT
I'm more convinced now that National rail inquiries gives it me when ask for via liverpool.
gnolife
4 Nov 2010
Johnstone
You can NOT go through Liverpool because Bidston (which you have to pass through) fails the fare check (it is more expensive to go Bidston - Stoke than Wrexham - Stoke therefore not valid)
SS4
30 Jan 2011
Edit the second.
I see no problem (not checked the easements though)
headshot119
31 Dec 2010
Dubai
Why do I have to pass through Bidston? I can go via Chester?
b0b
25 Jan 2010
that doesnt sound right.
both Wrexham General & Stoke On Trent are routeing points, no fares check required.
gnolife
4 Nov 2010
Johnstone
ah, youre right, forgot about that Merseyrail train! (stupid error really)
In which case, Rock Ferry fails the fare check as well!
and theres no way you can get around that one, sorry :(
bnm
12 Oct 2009
You are misunderstanding the Fares Check Rule there gnolife.
Both Wrexham General (Wrexham Group) and Stoke-on-Trent are routeing points, so no fares check is required.
Fares checks need only be carried out when the origin and/or destination station are not routeing points.
b0b
25 Jan 2010
I had a quick look, the only easements involving Wrexham were permissive easements.
I believe travel via Liverpool is allowed.
hairyhandedfool
14 Apr 2008
Wrexham and Stoke are routeing points, there is no fares check to make.
Only maps EM+CH can be used.
Stoke-Liverpool-Wrexham is a mapped route.
I don't know of an easement to stop it either.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Why is there a need for the Fares Check? As mentioned above by b0b both Wrexham General & Stoke On Trent are routeing points :?
gnolife
4 Nov 2010
Johnstone
Aye, its been a while since I read the instructions, so I'd forgotten that :(
