Routeing guide station
sonic2009
19 Jan 2010
Crewe
If a journey between two stations in a Routeing Group share the same group.
Can you travel either :
Direct from A to B or B to A via C aslong as the journey is within 3 miles of the shortest route.
So A to B is 3 miles & B to A via C is just under 6 miles.
And unless there is a BOJ restriction on the ticket. You could stop at C for a few hours.
I read it online on National Routeing Guide as you can but just checking to make sure.
What are A, B and C?
A concrete example would help to flesh out the details.
Independent of the Routeing Points involved, you can take an alternative route within 3 miles of the shortest route. There is nothing in the Routeing Guide that says this can't involve a double-back. There would need to be a specific negative easement for that journey/route to rule it out.
There is also a provision in the Routeing Guide which lets you double back via a common Routeing Point, although the wording implies that it is for interchange purposes rather than breaking your journey.
Haywain
3 Feb 2013
Longport to Stoke on Trent is about 2.75 miles (one way), which rules out using the 'within 3 miles' clause.
