I wonder if anyone can produce any useful responses to this query:
If I understand correctly, The National Routeing Guide says that where you have a choice between two routed tickets and you choose one more expensive than the other, you may use this ticket via the cheaper route also.
My query is what if the more expensive ticket is in fact cheaper at a given time due to a more lenient restriction code?
For example, Birmingham Stations to Glasgow Central/Queen Street:
Looking at the prices of the off peak returns (SVR), there is a ticket via Preston which costs £119 and carries restriction 2U, and is thus valid after 0415. There is a cheaper SVR priced by CrossCountry, 'Via York', which costs £115.70, but carries restriction 2V and is therefore not valid on trains timed to depart before 0930. Am I correct in thinking that between 0415 and 0929 inclusive the ticket that should be purchased is the 'Via Preston' SVR even if I wish to travel via York? And that the 'Via Preston' ticket should be accepted? Or would it be excessed to a 'via York' SOR?
