Route Home - YRK - GTW
fkofilee
19 Jul 2015
Hi Guys
Another Routing Query. I have 2 x Off Peak Returns.
One - YRK to Manchester Stations
Two - Manchester Stations - GTW
Question for the floor - Can I travel via KX / STP to get home from YRK (Via Doncaster etc) or must I go via Man Picc.
Routing Calulator says the listed below but I am unsure if I can do this route to KX because of the Manx Stations split.
CyrusWuff
20 May 2013
Nice and simple. Yes, you do have to go via Manchester with such a combination. Whilst your journey is York - Gatwick, you'd have to look up York - Manchester and Manchester - Gatwick separately in the Routeing Guide to determine valid routes.
fkofilee
19 Jul 2015
Thank you for confirming :) - Just wanted to check. Thats fine on my end.
Mcr Warrior
8 Jan 2009
This wouldn't be the quickest of journeys, but after travelling via Manchester Stns, is the OP still able to route via Kings Cross or St Pancras en route to Gatwick Airport, on an Off Peak return ticket?
What other routeings might be possible as well as via Euston?
Reading? Kensington Olympia? Marylebone?
Nunners
19 Oct 2018
They'd be able to go out of Euston, Marylebone, St Pancras and Paddington but not Kings Cross. They'd be able to do Kensington Olympia as well
alistairlees
29 Dec 2016
York to Manchester is valid via Sheffield, and Manchester to Gatwick Airport is valid via Sheffield, so you could go York > Sheffield > St Pancras > Gatwick
CyrusWuff
20 May 2013
My apologies. I was unaware of York - Manchester being valid via Sheffield, so I stand corrected on that front. But with that in mind, and no BoJ restriction, I'd agree that you don't have to use such a combination to do Sheffield - Manchester - Sheffield for no reason.
