Route excess between super off peak and off peak.
blimmo
30 Jul 2025
West Mids
I intend to travel from Coventry to Harlow Town via WCML on the way out and via High Wycome on the way back. Both directions will be on the weekend.
I'd like to buy a Super Off Peak routed via High Wycome (https://www.brfares.com/!faredetail?orig=COV&dest=HWN&rlc=YNG&rte=305&ldn=1&tkt=OPR) then excess it on the return outbound direction to Any Permitted (https://www.brfares.com/!faredetail?orig=COV&dest=HWN&rlc=YNG&ldn=1&tkt=SVR). However the any permitted ticket has no super off peak.
Is this still allowed? What are the general rules for doing route excesses when the ticket types are not the same?
Yes, that's fine. There is no requirement for a change of route excess to be between the same ticket types.
Yes it's allowed. If Coventry ticket office don't know how to do it, the Train Manager likely will.
Haywain
3 Feb 2013
I'd like to buy a Super Off Peak routed via High Wycome (https://www.brfares.com/!faredetail?orig=COV&dest=HWN&rlc=YNG&rte=305&ldn=1&tkt=OPR) then excess it on the return direction to Any Permitted (https://www.brfares.com/!faredetail?orig=COV&dest=HWN&rlc=YNG&ldn=1&tkt=SVR). However the any permitted ticket has no super off peak.
You would, I think, want to excess it for the outward leg.
Adam Williams
2 Jan 2018
Warks
Wouldn't boarding the Avanti train with the route high Wycombe ticket be risking prosecution?
It's a risk from the newest NRCoT.
A backwards change for passengers given the amount of hassle it is to find someone competent to issue an excess in the first place.
Yes. No entitlement to buy this excess onboard now. So you're on your own to find a competent member of staff prior to that.
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
But surely not finding a staff member who actually knows how to do it, is the same as not having an opportunity to buy before you board? :lol:
blimmo
30 Jul 2025
West Mids
If I could still get a refund for the ticket after the day of travel I would just buy the excess in advance by finding the right ticket office that would let me. But the combination of both of these NRCoT changes is particularly annoying here.
tomoufc
12 Dec 2014
I would ask at the ticket office and, if they refuse, buy a new ticket and submit a complaint later.
redreni
24 Sep 2010
Slade Green
Yeah, given the new NRCoT I would be trying to buy the ticket and excess the outward leg in the same transaction, at a ticket office. And if they can't or won't do it, buy the more expensive Any Permitted ticket under protest, perhaps after discretely recording the conversation, and then write in to the TOC's customer services seeking a refund of the amount overcharged.
Otherwise, the risk of buying a ticket that isn't valid for the desired route in the outbound direction would be that you just can't travel, or can't travel by the desired route, or you have to buy a second ticket.
In my experience it's more likely that they will do the excess but incorrectly do it as the full difference rather than half of it. In my experience however customer services tend to refund that fairly readily.
blimmo
30 Jul 2025
West Mids
Is the break of journey restriction on the original super off peak ticket in effect if I excess the outbound leg? The any permitted off peak ticket has no such restriction.
No, if you excess your ticket then the restrictions of the new fare (i.e. no bar on break of journey) apply to the relevant leg of your journey.
Indeed if you do break your journey when not allowed on a walk up ticket (can't remember about Advances) the remedy is an excess to the cheapest ticket for your journey that would permit it.
redreni
24 Sep 2010
Slade Green
And it's most unclear what the remedy is if no such ticket exists...
redreni
24 Sep 2010
Slade Green
Given that all Anytime fares allow break of journey there can't be many such cases.
What about Dartford to Reading breaking at Canary Wharf? No break of journey restriction on the ticket, but one has been inserted into the NRCoT regardless of the ticket held. So, if I hold a CDR what's the excess?
Ah, forgot about the Liz core issue where it's treated like a Tube transfer. That should probably be delved into on the dedicated thread as it's not "normal".
blimmo
30 Jul 2025
West Mids
Does that include only one direction of a return?
blimmo
30 Jul 2025
West Mids
Well I was right to be worried. Made the outbound journey today. I had asked about getting the excess at canley ticket office in advance so I knew they could do it (though it took a lot of encouragement and suggestions from me!). Unfortunately their printer was broken so they were unable to print me any tickets and gave me an authority to travel to attempt buying at Coventry.
At Coventry the clerk took seemingly multiple minutes to find the base ticket I wanted (before I'd even asked about the excess) then point blank refused to sell the excess because "Avanti don't do super off peak so you can't excess from it". I told him I'd seen the TIS at canley so I knew it could be done but he was having none of it. When I asked to speak to someone else his colleague told me "he's been doing this for 20 years" like that means he's competent. In the end I bought only the base ticket intending to excess on board.
I couldn't find the guard on the LNWR train I boarded so I left the train at rugby and finally found a ticket office that would sell me the excess. Props to the guy there who seemingly had to fight through 3 separate data entry screens to issue it (and interestingly scanned the mini Aztec on my CCST).
I will be complaining (again) about the Coventry ticket office staff but thankfully I am moving next week so I will probably never have to interact with them again.
"Been doing it years mate" is so classic. It never gets old.
No, YOU, the customer with a detailed and well-researched request, are simply wrong, go away.
blimmo
30 Jul 2025
West Mids
What really gets to me is they seem to be offended at me questioning them. It seems to never cross their mind they might be wrong. I guess it comes from dealing with clueless passengers all day.
redreni
24 Sep 2010
Slade Green
I've had them tell me how many weeks of training they've had. In some cases one wonders what they've covered.
But anyway, there's no reason to suppose their training would have focussed on the specific journey I now want to make and the specific tickets I now want to buy, so it's hardly surprising that having researched the matter in advance, I may know something they don't about my intended journey and ticket(s). I'm not claiming to know more than them about anything else.
I'll say it right now: the booking clerk you encountered at Coventry is utterly incompetent. That they've been doing the job for 20 years means they have no reasonable excuse for their incompetence.
I suggest you lodge a complaint (not that I trust Avanti to do anything with it; they are unable to control the behaviour of their ticket office staff!)
I couldn't find the guard on the LNWR train...
Very rare to see a Guard on West Midlands Trains (who operate LNR brand) services, so this doesn't surprise me. I'd be shocked if you had a ticket check on WMT, though it can happen very occasionally.
Please do let us know how you get on. If Avanti do not give a decent response, you can escalate the matter to the Rail Ombudsman (not that they are any good, and not that Avanti would be remotely bothered about being referred to the Ombudsman; they really couldn't care less!)
Indeed; I am so glad that in 2026 I rarely have to interact with ticket offices. I do not look back fondly on being mislead, mistreated, missold and refused sales by ticket offices on dozens of occasions throughout the years.
Bring on the day that all fares - including excesses - can be bought online and I never have to deal with them ever again.
blimmo
30 Jul 2025
West Mids
I have done so today.
I assumed they would be hiding in the back cab so I boarded at the rear and actually knocked on the door. When I got off at rugby though they seemed to be in the middle of the front unit so I think they may have actually been checking tickets.
