Round UK ‘circumnavigation’ by train
Mainliner
1 Nov 2010
Northumberland
Hi all. I couldn’t immediately find a thread covering the above topic. What I have in mind is an around England, Scotland and Wales trip, as close to the coastline as possible, with overnight stays as required, but not using branch lines or doubling back anywhere, so I realise that on that basis some parts will necessarily be a bit inland. Although sleeper trains would reduce time, they would miss out parts of the coastline on which other services run, so they and the Great Britain type tours wouldn’t be appropriate. I would start from Morpeth or Newcastle, and finish back there. It’s not important whether it’s clockwise or anti-clockwise, although the timings on some sections might influence that decision.
If there’s an existing thread on that sort of thing, I’d be grateful for a link, otherwise happy to receive itinerary suggestions, estimates of how long it’s likely to take (which is not an issue - I’m retired :D), comments on whether rover or separate tickets are likely to be the best option (I have a railcard), etc.
Many thanks in advance!
Edit: an AI answer suggests that this would take a week, with an All Line Rover likely to be the best option.
etr221
10 Mar 2018
My instant thought is that, once you've decided your ground rules, and assuming it's rail all the way (no bus or other non-rail gaps) with no branches/dead ends/doubling back, the itinerary will be fairly set, just a matter of which way round you go. Perhaps the only decision is whether you confine yourself to National Rail, or use others (e.g. the Ffestiniog). But I think that either way, you'll be a long way from the coast much of the time.
In some ways, an all line rover is overkill unless you intend to spend all day going on long distance trains. For example, the time in Scotland is cheaper, and potentially just as flexible on a cheaper Highland Rover. Similarly there are day tickets covering Cornwall. The 'trunk' journeys can be made using advance fares.
A S Leib
9 Sep 2018
How strict are you on that rule? That means skipping out Cornwall and most of Devon and most of the Welsh coast for a start, if absolutely not wanting to double-back, unless using buses or preserved railways.
Acathater
11 Dec 2025
NorthWest
Also means walking/bussing between the two Dorchesters, and also the two Yeovil stations
Mainliner
1 Nov 2010
Northumberland
I don’t want to double back, but I’ve done Devon and Cornwall and the Far North line before, so I don’t mind skipping those. Re the latter, I’d go Inverness-Kyle, bus down through Skye and then go Mallaig-Glasgow.
Happy to use preserved railways, e.g. Porthmadog-Blaenau.
Mainliner
1 Nov 2010
Northumberland
Thanks, I’ll do some comparisons!
Farigiraf
23 Jul 2023
Bridge on the River Cam
Buses from Kyle/Broadford to Armadale ferry pier are few and far between and don't have perfect reliability so I'd advise you to be absolutely sure of your itinerary through this section before setting out, as there are practically zero guarantees that you'll make the connections - the bus, ferry and train companies don't talk to one another very much. E.g. the only connection I can find involves a 9am bus from Kyle, a 20 min connection at a road near Broadford, and then a 10 min connection to the ferry at Armadale.
Though it can be expensive, there are prebookable taxis that can fill in this gap reliably. The Scottish Grand Tour rover ticket gives an entire 10% off local taxi bookings. Plus hotel options at Kyle/Mallaig/Broadford etc, which also add in a safety buffer, but availability and price can be brutal at the more pleasant times of the year to travel.
While it's a beautiful bit of the country, you can save a lot of money and stress by opting for the Fort William - Inverness coach (via Loch Ness) and choosing to do a 1 or 2 day trip out to Mallaig (from Fort William) or Kyle/Skye (from Inverness) instead if you are set on riding those rail lines (which are certainly worth the time).
Brightonboy
20 Jan 2025
Suffolk
Similarly, would Norwich - Great Yarmouth via Acle - Reedham (via Berney Arms) - Lowestoft - Ipswich count as doubling back twice even though there are no intermediate stations between the termini and the diverging junctions? If you rule them out then that is large chunks of Norfolk and Suffolk excluded.
Thinking about it, even Peterborough - Norwich - Ipswich would involve a doubling back at Norwich....
Sir Felix Pole
21 Oct 2012
Wilmslow
The West Coast is the trickiest I think - you'll need to take the other modes to fill in the gaps if you really don't want to double back:-
Bus Inverness to Fort William or Bus / Ferry Kyle Of Localsh to Mallaig via Skye as discussed above.
Bus Stranraer to Dumfries.
Bus Lancaster to Knott End. Ferry Knott End to Fleetwood, Tram Fleetwood to Blackpool.
Bus Bangor to Caernarfon, Welsh Highland Rly. Caernarfon to Portmadoc. or Festiniog Rly Blaenau to Portmadoc.
Bus Aberystwyth to Carmarthen.
If you wanted to do Devon and Cornwall again it is possible to do the 'Atlantic Coast' route by bus (eventually!) - Okehampton to Bodmin via Bude, Camelford and Wadebridge. Barnstaple to Taunton via Lynton and Minehead is also possible by bus.
nr758123
3 Jun 2014
West Yorkshire
Also the two Burscoughs, Corkickle & Whitehaven.
If the occasional bus or ferry is allowed, then can I suggest McGill's bus from Largs to Wemyss Bay, because it would be a shame to miss out Wemyss Bay station.
Mainliner
1 Nov 2010
Northumberland
Yes, I’ve done Broadford-Armadale by taxi before, and realistically it would probably need that!
Robin Edwards
1 Dec 2013
This was the approach I took on my 14day all-lines rover in 1982 although hugging the coastline wasn't adhered to as much as I could have based on other factors such as covering some new lines, haulage and shed visits as well.
I started London Victoria to Ramsgate and finished Southend Central to London Fenchurch Street in around 7 or 8 days, then spent the rest of my time covering other circular routes starting out and ending closer to home. I didn't try to do many of the branch lines but could have at the expense of more inland visits.
I also missed much of Scotland as I'd done those lines the previous year.
chris53
12 Feb 2024
West Lancashire
The ferry has irregular times and doesn't run at all on a Monday so some planning would need to go into that
Hadders
27 Apr 2011
I've done this a few times using public transport but you do need to be aware of what services are operating as they tend to change frequently and it depends on school days. Broadford Post Office is the usual interchange stop if changing from a service towards Portree into a service towards Armadale.
A quick look at timetables for Wednesday 2nd September:
Scottish Citylink 917:
Kyle of Localsh dep. 10:43 or 15:28
Broadford PO arr. 11:02 or 15:47
Scottish Citylink 915:
Kyle of Localsh dep. 12:00 or 16:00
Boradford PO arr. 12:19 or 16:19
Stagecoach 152:
Broadford PO dep. 16:30
Armadale Pier arr. 17:02 (ferry departs at 17:40)
If the connection was missed then there is a get out of jail Scottish Citylink 917 departure from Broadford to Inverness.
Mainliner
1 Nov 2010
Northumberland
Thanks for those suggestions!
Mainliner
1 Nov 2010
Northumberland
Stagecoach 152:
Thanks - depending on what time I get to Kyle, I might try for the 16:30 departure from Broadford, with a taxi backup if it goes wrong!
Mainliner
1 Nov 2010
Northumberland
It’ll be interesting to compare the experience 44 years on :)
Robin Edwards
1 Dec 2013
Indeed so @Mainliner
Were I to have the energy to repeat myself, there are a few changes I would make but then my priorities will have changed. A circumnavigation isn't conducive with visiting depots and tracking down wanted haulage etc. Also I took rudimentary camping gear in 1982 and slept on a few very late/early trains too. Not for the feint of heart if plush accommodation needs to be part of the plan as it definitely would for me 44 years later!
I took the approach that my trip was 100% rail with no buses and that meant an element of out-and-back. Personally I wouldn't change this aspect. No internet in 1982 btw :)
If a summary of my movements in 1982 helps or adds interest, I'm happy to pen a few lines.
Mainliner
1 Nov 2010
Northumberland
A summary of your route would be interesting, but no rush, as I’ll probably not be doing this until next Spring.
Similarly to yourself, I Inter-Railed around Europe in pre-internet 1981 armed only with a copy of the Thomas Cook International Timetable. I did several overnight couchette journeys to save time, but nowadays I will certainly be taking more comfortable overnight breaks!
Robin Edwards
1 Dec 2013
The joys of 70/80s roving was carrying a rucksack full of Timetables :)
Mainliner
1 Nov 2010
Northumberland
I’ve had a couple of interesting evenings pencilling in a draft itinerary. This includes a couple of short double backs and bus/taxi/walks in order to achieve the main objective. It does look like it’ll take 8 days.
I’ll need to revisit this before I go next year, in light of timetable changes, and I’ll tinker with it to see if I can avoid a couple of late nights, including trying it in the opposite direction.
Adding up the individual fares (with a railcard), there doesn’t seem to be a huge difference between those and an All Line Rover, so I think I’d take the latter, mainly for flexibility, as there are so many connections I’d be surprised if it all went smoothly! Also saves hassle of buying numerous tickets.
It appears that only a small percentage of the journeys have first class (or first class with any catering offer), so I don’t think that would be worthwhile.
So this is how it looks so far, subject to amendment…
Day 1
Newcastle - Aberdeen 0903-1303 £33
Aberdeen - Inverness 1341-1558 £7
Inverness - Kyle 1754-2034 £11.95
Day 2
Kyle-Armadale taxi, first Armadale ferry
Mallaig - Glasgow 1032- 1534 £31.55
Glasgow - Wemyss Bay 1617-1715 £6.6
Wemyss Bay - Largs Bus 1730-1746 £5
Largs - Kilwinning 1816-1841 £5
Kilwinning - Troon 1858-1909 £3
Day 3
Troon - Carlisle 0939-1142 £16
Carlisle - Carnforth via coast 1210-1643 £21
Carnforth - Preston 1744-1809 £9
Preston - Blackpool N 1829-1854 £3
Blackpool S - Preston 1920-2008 £2
Day 4
Preston - Wigan 0900-0911
Wigan - Ince 0937-0940 £2
Ince - Southport 0947-1030 £7
Southport - Moorfields 1048-1135 £5
Moorfields - Bidston 1151-1210 £5
Bidston - Shotton 1236-1302 £3
Shotton- Llandudno 1402-1531 £4
Llandudno - Blaenau 1610-1729 £5
Blaenau - Porthmadog Bus
P’madog - Machynlleth 2056-2253 £19
Day 5
Machynlleth-Shrewsbury 1007-1118 £15
Shrewsbury-Llanelli 1131-1530 £16
Llanelli - Cardiff via Barry 1632-1841 £4
Cardiff - Bristol 1900-1951 £14
Day 6
Bristol - Exeter 0811-0908 £6
Exeter - Yeovil Jct 0935-1026 £4
Yeovi J - Yeovil PM 1045-1105 £2
Yeovil PM - Dorchester W 1134-1208 £6
D’ster S - Southampton 1310-1428 £5
Southampton - Havant 1445-1530 £5
Havant - Brighton 1600-1705 £5
Brighton - Eastbourne 1726-1759 £9
Eastbourne - Ashford 1851-2010 £12
Day 7
Ashford - Ramsgate 0923-1000 £4
Ramsgate-Chatham 1021-1128 £6
Chatham - Ebbsfleet 1158-1219 £4
Ebbsfleet - Stratford I 1235-1246 £15
Stratford I - Stratford DLR 1300-1315
DLR to Stratford
Stratford - Ipswich 1337-1435 £15
Ipswich - Lowestoft 1506-1636 £12
Lowestoft - Norwich 1647-1731 £10
Norwich - Peterborough 1750-1927 £7
Day 8
Peterborough - Lincoln 0934-1035 £10
Lincoln - Barnetby 1044-1116 £6
Barnetby - Hatfield 1153-1313 £12
Hatfield - Hull 1419-1513 £2
Hull - Seamer 1521-1633 £4
Seamer - York 1659-1743 £7
York - Sunderland 1852-2022 £15
Sunderland - Newcastle 2031-2051 £3
Acathater
11 Dec 2025
NorthWest
I think you've made an error with
Day 4
instead of Wigan-Ince why not
Preston-Wigan North Western
Wigan North Western - Wigan Wallgate (it's virtually across the road)
Wigan Wallgate - Southport
Mainliner
1 Nov 2010
Northumberland
Day 4
Thanks, I thought there might be an error or two in areas that are unfamiliar to me!
8ace
25 Dec 2019
Brighton
The 1445 from Southampton goes to Brighton, no need to change at Havant (not much there really).
(edited) Also you buy a Southern DaySave ticket that will cover you all the way from Southampton to Ashford for £26 which would save you a fiver if you decide against the ALR.
