Class15
Indeed. Better take it from Aylesbury.Class 168 are not tripcock fitted so cannot operate on that route.
Class 168 to Princes Risborough
Only the 168/3s, the other 168 subclasses can and do work via AmershamClass 168 are not tripcock fitted so cannot operate on that route.
Class 165 to London MaryleboneClass 168 to Princes Risborough![]()
I assume you mean Wembley Central as the Bakerloo Line doesn’t go to Wembley Stadium.1972 Stock to Wembley Stadium.
Yes I did meant Wembley Central! My bad.I assume you mean Wembley Central as the Bakerloo Line doesn’t go to Wembley Stadium.
Class 710 to Watford Junction
Not possible from Tynemouth as Sunderland is on a different line. You’d need to choose a location on the yellow line to move to. Unfortunately that means the following move is also invalid as no valid move from Tynemouth would take you to anywhere you could board a 180.Class 599 to Sunderland.
Class 156 to SunderlandClass 599 to Heworth
Should be fine now, I have no knowledge of T&W Metro
