Rhätische Bahn (CH)
iknowyeah
11 Aug 2016
I have booked FIP Coupons for SBB, SP and BLS. I will be staying in Bern and want to try and travel on the Rhätische Bahn, however looking at the SBB planner I'm struggling to find a journey that leaves enough time for a decent days walking of over an hour or two. Is this just journey times being this long or am I missing a trick?
Alfonso
22 Jul 2017
You can get to Landquart in 2h10 or Chur in 2h20, so it would be quite a long day but doable. How about taking the Rhb Arosabahn from Chur to Arosa? Plenty of walking options. If you're not after the rhb specifically but little red trains in general, then going to Visp or Brig ( a brilliant train nerd spot and a nice town for normals too) only takes about an hour then you could travel for another hour on the matterhorn gottard bahn ( former bvz and FO) to Zermatt or Fiesch, for example.
eastwestdivide
17 Aug 2009
S Yorks, usually
Think it is just the journey times. How about walking down past the spirals Preda to Bergün? This should be possible:
Bern 0702 to Preda 1129 (via Landquart/Samedan)
Bergün 1647 to Bern 2028 (via Chur)
and later connections back are possible.
30907
P
You could also within the day do all or most of the ex-FO (MGB)/RhB circuit with time for a linear walk (Rhine Gorge? Realp to look at the Dampfbahn?
nwales58
15 Mar 2022
notsure
What kind of walking? Level valley bottom, level panoramic or getting sweaty?
I'd second Arosa, it's now 11kV with the same stock as mainline RhB, as you climb out of the end of the valley into a big bowl and a quick painfully expensive cable car gets you high ifyou want short walk with views.
Klosters is 40' less travel each way, easy walking but not as dramatic unless you go up Gotschnagrat (ouch again) for a quick walk at height.
Non-RhB but similar time: Andermatt, MGB rack up from Göschenen, loads of easy walking in massive valley junction, maybe train up to Oberalp for a wander with even better views.
blackfive460
23 Jun 2010
Arosa would be a good choice at the moment as two diagrams are currently loco hauled by Ge4/4IIs instead of Allegra EMUs.
iknowyeah
11 Aug 2016
I think maybe Oberalp might be the one we decide on, weather permitting. I'll have a look at Arosa too and decide nearer the time, thank you!
Some major infrastructure damage recently in southern Switzerland, notably in Ticino and Wallis/Valais.
I haven't seen any reference to RhB territory, but it's not far away.
The A13 motorway near the San Bernardino pass was severed, and there has been road/rail damage between Visp and Zermatt (part of Glacier Express route).
Worth checking local conditions before you go.
Dozens of people were evacuated due to a landslide in the Mesocco and Calanca valleys in the southeastern canton of Graubünden.
The houses of those missing were destroyed in the landslide in Mesocco. Streets in the village were flooded, according to cantonal police.
Another woman had been reported missing but was found on Saturday morning.
A stretch of some 200 meters on the A13 highway to Italy was destroyed.
nwales58
15 Mar 2022
notsure
MGB is currently buses between Visp and Täsch, as above. So Brig-Andermatt-Disentis not affected.
RhB has no disruptions currently.
A13 damage is south of the watershed.
nwales58
15 Mar 2022
notsure
Some confusion in that NCE article. Castiel is between Chur and Arosa , not on either route to Davos.
As I understand it, during replacement of the bridge a non-approved method was used. Incorrectly not accidentally demolished. The work was completed but an environmental impact investigation is taking place.
Chur-Arosa trains are showing as running normally.
... en route to Davos so part of the Glacier is also down.
Glacier Express trains run St. Moritz-Tiefencastel-Chur-Brig. Not via Davos. The damage that affects them is Visp-Zermatt as LNW-GW pointed out.
RailWonderer
25 Jul 2018
All around the network
They put it down to miscommunication and bureaucracy between the Canton transport authority and federal authorities so yes, accident is probably a generous way of putting it.
I plan to go up the Matterhorn early next year so I hope it's fixed by then!
Gordon
11 Feb 2011
Summing up the current situation
1) MGB Visp - Taesch closed UFN (replacement buses operating). Taesch - Zermatt shuttle operating
2) Furgangen Bellwald - Oberwald on the Brig - Andermatt line closed
3) No Furka base tunnel car shuttles operating because the access road to Oberwald is blocked
4) Absolutely no affect on RhB network (the destroyed motorway in the Misox valley is where the long closed isolated RhB Bellinzona - Mesocco line ran
5) the Glacier Express is running Brig - St Moritz
6) the 'wrongly destroyed bridge' on the Arosa line is a classic non-story from a sensationalist writer
Although I haven't seen the detail, my good knowledge of the area indicates that items 2 and 3 are caused by the same problem - probably where the Goms valley is at its narrowest.
30907
I think you must mean Chur not Brig :) as 2) is definitely correct. The MGB site says no RRBs are possible which fits with 3). Quite drastic!
nwales58
15 Mar 2022
notsure
The Fiesch-Oberwald closure with the road closed too is new. Drastic as you say and currently no timescale. It seems to be flooding which has been progressing down the valley since yesterday, 29/06/2024.
Glacier Express is indeed only running St.Moritz-Chur. Their web site says travel to/from Brig via Bern and Zürich! Although I'd rather go via Brünig if the point of the trip was scenery.
This weekend's storms have caused substantial damage in upper Valais. Highest flows in the Rhone are expected tonight (Sunday) so there could be more damage by tomorrow.
Looking at road information, Furka and Grimsel passes currently closed due to rock falls.
Road closed between Oberwald and Niederwald still (re-opened below there). Flooding in every side valley has dumped gravel and mud into the main valley bottom with damage to road, railway and villages in multiple places. Some villages evacuated. Sounds as if the railway could be closed for some time.
Gletsch-Oberwald, part of the seasonal steam service over the old Furka line, is damaged by flooding and will not re-open on Thursday as planned.
Brig-Andermatt showing as RRB between Fiesch and Oberwald today and, my guess, for some time. Road still closed to normal traffic though.
Lower down the Rhone valley Gampel-Steg - Leuk is currently RRB too, Visp-Sierre RRB for fast trains due to flooding.
Serious damage generally, on the roads not just the Furka and Grimsel but the Simplon pass currently closed too by landslides on the south side. The Saas valley, next one E of Zermatt, is heavily damaged.
SBB is showing the only rail closure today is between Sierre and Visp in the Rhone valley, expected to reopen on July 4.
The volume of debris on the tracks is larger than first thought.
With last weekend's bad weather, the Rhône deposited a lot of mud and sand in the tracks.
The reason why the first prognosis was wrong is that no one could have imagined the quantity of these deposits and the difficulties in cleaning them.
The implication is that the Glacier Express route is now clear.
rvdborgt
24 Feb 2022
Leuven
The SBB planner is still showing cancelled trains between Fiesch and Oberwald. MGB still have a warning on their website.
