RFID tags on carriages
dbrb2
I've noticed that quite a few carriages I see now have small grey and white rectangular RFID tags bolted to them at approximately platform level - does anyone know what they are used for, and whether they are being rolled out across the whole network (since many trains have them, but lots do not) ? I assume it's something to do with asset tracking....
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
You’re probably going to have to be a bit more specific - what trains have you noticed them on? Where are they? What do they look like - photographs available, perhaps?
dbrb2
This isn't my photo - I couldn't find one immediately - but it is a result of an image search for the kind of thing I have been seeing.
They seem to be mounted at the far end of vehicles. I've seen them on passenger, freight, and network rail trains - but not all of them - so it may be something that is only being rolled out slowly, or perhaps by region, depot, or some other grouping!
43096
23 Nov 2015
They are for cleaners to mark job done I think. At least that's what they are for in lots of offices.
Or are for use with GOTCHA, HABD, WILD etc lineside equipment to identify the vehicle that has activated the system.
Ashley Hill
8 Dec 2019
The West Country
I asked a similar question a few years ago. Below is what I was informed at the time.
Some routes are fitted with devices that monitor the wheel bearing harmonic frequency of passing vehicles. Each wheel bearing it seems has a unique harmonic frequency. As a vehicle passes such a detector it identifies the vehicle from the RFID and reads the harmonic frequency of the wheel bearings. Changes in harmonic frequency since the last reading indicates there has been wear in the bearing.
ac6000cw
10 May 2014
Cambridge, UK
This thread I assume - https://www.railforums.co.uk/threads/mk3-mystery-fitting.235253/
rjennings
26 Mar 2018
Similar to this one? Noticed on the side of 92041 as it was stopped in Rugby last week and curious also if anyone knows what it is for.
irp
14 Aug 2023
Cov, UK
I have no idea what this means.
I don’t even know what an RFID is.
RFID is an RF (Radio) ID (Identification) Tag. Your Debit/Credit Card most likely has one (See Wireless Credit Card Machines where you just tap your Credit/Debit Card) . They work on 125kHz or 13.something MHz, and transmit their ID [and other data] when a reader is in close proximity. The transmit power output of the reader is just enough for them to power themselves [there is no on-board power]
[They can actually be small enough to put on N-Gauge layouts to identify a train, and they worked fine, but I found this was only true when the power was off! But that's all off topic :)]
23 Nov 2015
HABD - Hot Axle Box Detector
WILD - Wheel Impact Load Detector
GOTCHA - company that makes lineside monitoring equipment
Ashley Hill
8 Dec 2019
The West Country
HABD - Hot axle box detector. Measures the temperature of passing axles. If one is unusually warm it alerts the controlling signaller and says which axle in the train it is so it can be examined.
WILD - Wheel impact load detector. Measures the impact forces of damaged wheels.
GOTCHA - Best explained in this link.
ac6000cw
10 May 2014
Cambridge, UK
The passive, fixed-data track-mounted 'balises' used as part of modern cab signalling systems and for things like tilt control on the WCML are basically RFID tags as well - passing trains wirelessly power them up and read the data.
