Revised Southern/Gatwick Express service today
ushawk
5 Nov 2010
Eastbourne
Because of overrunning work between Victoria and Clapham, a revised service will operate on Southern services and most Gatwick Express services will be suspended. Revised service pattern is below (copied from NRE website) -
Southern Main Line services
A revised service will run on the following routes:
* London Victoria - Gatwick Airport - Brighton: Two trains per hour calling at East Croydon, Gatwick Airport, Three Bridges, Haywards Heath then all stations to Brighton.
* London Victoria - Littlehampton / Eastbourne / Ore: Two trains per hour from London Victoria to Littlehampton and Eastbourne or Ore.
* London Bridge - Portsmouth Harbour / Southampton: Two trains per hour.
* London Bridge - Horsham: Two trains per hour.
* Reigate - Tonbridge: Hourly service.
Southern Suburban services
London Victoria routes
* Watford Junction - Caterham: hourly service
* Shepherds Bush - Caterham: hourly service
* Clapham Junction - Sutton via Crystal Palace: will not run
* Shepherds Bush -Epsom or Epsom Downs via Selhurst: 2 trains per hour
* London Victoria - Dorking / Horsham will run to / from London Bridge. 2 trains per hour.
London Bridge routes
London Bridge services will be mostly unchanged except:
* London Bridge - London Victoria via Denmark Hill will be replaced by buses
* London Bridge - London Victoria via Crystal Palace will terminate at Streatham Hill
* London Bridge - Tattenham Corner will run as a London Bridge to Caterham/Tattenham Corner service, dividing at Purley.
East Grinstead / Uckfield routes
* London Bridge to East Grinstead - 2 trains per hour
* Oxted - Uckfield - hourly service.
Gatwick Express
Most Gatwick Express services will not run. Passengers should use Southern services to travel between London Victoria and Gatwick Airport.
Passengers may use London Underground via any reasonable route.
paul1609
28 Jan 2006
K
Sadly, The overrun was caused by a trackworker being seriously injured on the site. Work then had to be suspended for a period.
