Revenue inspectors card readers across rails
bilibalaaaaa
20 Jan 2025
reading
My question is whether card readers are preset to check if the journey of the train l’m being checked on is included. Say if I got checked on Thameslink, but I completed a GWR or a tube journey, will I still be charged maximum fare because I didnt complete a journey in the thameslink train?
signed
13 May 2024
ROI
No
A contactless journey (assuming you are talking about bank cards and not Oyster though that is sensibly the same idea) is delimited by the tap-on and tap-off and the maximum journey time.
You can take however many contactless-enabled mean of transport between those points.
Haywain
3 Feb 2013
Your question isn't clear enough to confidently give an answer. Is this one journey from somewhere on GWR to somewhere on Thameslink? Or is it more than one journey which is why you refer to a completed journey?
A check of a contactless card simply takes the card details to send to the back office and compare it with the touch in and touch out data during overnight processing. That is when it will be decided if a maximum fare is appropriate.
As others have said, you haven't given us enough details to completely understand your query. But if you're using contactless, the onboard check is only capable of checking that your card isn't in the list of blocked cards. That might be the case if payments for previous journeys have failed, for example.
At the end of the day each onboard check is transmitted to the TfL 'back office' and their system then reconciles this against the touch in/out data to work out whether you were touched in at the time of the inspection.
If you weren't touched in, then on top of any journeys you made that day, you card gets charged a failed inspection fee (I believe this is equivalent to a maximum fare) and it counts as one of your three "strikes" in terms of failed inspections. After three strikes, your card is blocked.
Oyster works differently; the touch in/out data is recorded on the card itself so the inspectors can verify whether you touched in before getting on the train. They would likely issue you with a Penalty Fare or take your details for prosecution if the check showed your Oyster card wasn't touched in. I don't think Oyster cards get blocked for failed inspections; the idea is that you'd be penalised on the spot anyway.
