Restoring Coventry-Nuneaton-Leicester-Nottingham Route
Stephen Lee
7 Jul 2019
https://www.midlandsconnect.uk/news...overnment-is-urged-don-t-ignore-the-midlands/
In the link, “Plans to reinstate direct services between Coventry, Leicester & Nottingham for the first time since 2004, with two fast trains per hour in both directions” has mentioned.
but i wondered if it will be good to extend its origin from Leamington Spa(i.e. Leamington Spa-Coventry-Nuneaton-Leicester-Nottingham)
Also i wondered if this materialised which TOC can operate this service.....
This proposal was discussed in a couple of threads last summer, I think the general consensus was it’s almost impossible to reinstate:
https://www.railforums.co.uk/thread...to-west-midlands-railway-connectivity.184669/
https://www.railforums.co.uk/threads/midlands-rail-hub-scheme-plans.166862/page-2#post-4078112
Dr Hoo
10 Nov 2015
Hope Valley
Obviously 'missing out' Nuneaton itself, whilst good for reasonably fast connectivity between Nottingham-Leicester-Coventry, means that local travel and interchange opportunities at Nuneaton into the WCML Trent Valley services aren't really improved.
30907
The old route avoided Nuneaton as you describe (is the bridge under the WCML still there?). It would be challenging to build a diveunder at an acute angle to allow reversal at Nuneaton - probably more difficult than Werrington! - but might not be impossible. The question is - would duplicating the service Coventry to Chilvers Coton be more cost effective than a complex new junction.
Despite the inconvenience of the change at Nuneaton, I suspect a half hourly Coventry-Nuneaton and an improved (2 slow 1 fast ph? 4tph?) Nuneaton-Leicester (-Nottingham?) frequency might be the upper limit.
As for starting back from Leamington - might be possible once HS2 takes pressure off Coventry.
Meerkat
14 Jul 2018
Is there room between Nuneaton and Leicester for two more fast trains (particularly as there would be a flat crossing at the Nuneaton end).
Better to have self contained fast Nuneaton-Coventry with good connections into longer and faster Birmingham-Leicester trains?
Stephen Lee
7 Jul 2019
It’s isnt ‘the plan’ at all. It’s simply a suggestion.
But there are proposals about it
Hopefully there is but I wondered if extending the west side termini to Leamington will be a good idea
Dr Hoo
10 Nov 2015
Hope Valley
With the problems of crossing the WCML Birmingham Loop on the flat at Coventry and the single track bottlenecks on the Kenilworth section the benefits would have to be pretty massive.
Does Leamington have a particular attraction for Leicester and Nottingham (noting that East-West Rail via Bedford to Oxford will provide further opportunities for links towards Oxford in future)?
Ianno87
3 May 2015
Leamington has a decent student population (from Warwick University)
Meerkat
14 Jul 2018
Right.
So why does that need a new service from Nottingham?
Because students are famously short of time and too lazy to change trains.
Any business case based on off peak travel on railcards is going to struggle a bit!
You would probably get them to/from Wigston without too much grief, the bit to Leicester would be the trickier bit.
Ianno87
3 May 2015
Right.
I didn't say that was the entire market or justification for the service, just an example of an obvious demand flow that could be picked up.
