Remaining GWR HST Diagrams
Starmill
18 May 2012
Bolton
Thanks for this, cactus.
South Wales:
0559 SWA - PAD 0855
0659 SWA - PAD 0955
0915 PAD - CDF 1128*
0945 PAD - SWA 1248 - may be an IET
1156 CDF - PAD 1407*
1321 SWA - PAD 1629 - may be an IET
1515 PAD - CDF 1723
1756 CDF - PAD 2001
2100 PAD - SWA 0112
Does anybody know what the status of these is, as of this week please?
Thanks! :)
Mag_seven
1 Sep 2014
here to eternity
Thanks! :)
I would assume they are still applicable this week - on the day you can check formations on "Tiger Rail".
Iris2.rail.co.uk/tiger/
Siemens Staines
30 Jul 2015
Thanks! :)
From journey check yesterday
09:45 London Paddington to Swansea due 12:42
Facilities on the 09:45 London Paddington to Swansea due 12:42.
This is due to a fault on this train.
Will be formed of 5 coaches instead of 9.
Last Updated:20/08/2018 08:21
13:29 Swansea to London Paddington due 16:32
Facilities on the 13:29 Swansea to London Paddington due 16:32.
So I believe it is booked an 800/3
In fact it was 800013 and was amongst a number of short formed or cancelled services to South Wales yesterday morning.
On weekdays I think the only hsts to Swansea now are three in at night, 1615, 1814 & 2115 from Paddington returning the next morning with 0529, 0559 & 0659 from Swansea.
ATW158Xpress
6 Dec 2016
Over the last couple of weeks the 16:15 has been a 800/3 numourus times so might have swapped to IET.
Siemens Staines
30 Jul 2015
I think it was 800/3 but it has reverted to hst this week. It seems to be related to the introduction of 802s on the 1633 Exeter which come ECS from North Pole. Last week the 1633 was formed by the hst off the 1209 Hereford - Paddington but this week that hst is working the 1615 to Swansea instead.
During the transition there have been several trains that have gone over to IET and then for a period reverted to hst, and at a later date gone back again. Some Cotswold trains went over to IET for several months (admittedly not always running) before reverting to hst in May and have been since - the 0921 and 1522 spring to mind. I find it difficult to keep track of the changes, especially when for many weeks significant engineering work line closures completely change the picture.
cactustwirly
10 Apr 2013
Definately an IET unfortunately...
Um, looks like I'll have a busy Autumn updating this thread.
If you're looking to bash the GWR HSTs then I strongly suggest you do it ASAP, especially now the 802s have been introduced
DaveHarries
12 Dec 2011
England
A look in RealTimeTrains suggests that, effective 03rd September, including on Saturdays, it seems that the following will join the IET club: 1A35 is booked IET all the way through October too so I guess this is now permanent:
5A77 Penzance T&RSMD - Penzance
1A77 0541 Penzance - London Paddington, via. Westbury
1C80 1203 London Paddington - Penzance, via. Westbury
1A35 1742 Penzance - London Paddington, via. Bristol Temple Meads
5A35 London Paddington - North Pole IEP Depot
Going by RTT it seems that the return diagram to provide the 5A77 for the following day will be:
5C71 0606 North Pole IEP Depot - London Paddington
1C71 0635 London Paddington - Penzance (not calling Westbury)
1A88 1204 Penzance - London Paddington (not calling Westbury)
1C92 1803 London Paddington - Penzance (not calling Westbury)
5C92 2330 Penzance - Penzance T&RSMD
Dave
PHILIPE
14 Nov 2011
Caerphilly
Dave
You seem to be posting the same thing on two threads but this should be noted:=-
www.railforums.co.uk/threads/gwr-intercity-express-train-iep-initial-diagrams-allocations.153431/page-45 Post #1324
Clarence Yard
18 Dec 2014
And for those of you that haven’t followed that link, RTT is not your way to find out the next introduction dates. 24th September is when those diagrams cut over, not 3rd September.
It is all to do with how GWR upload their LTP plans in block dates. They are modified to the correct date by the STP team but such is their workload at the moment the result is the uploads have got out of synch.
The original date for these diagrams was the 20th August. It was then put back to the 10th September and is now the 24th September. Delayed unit deliveries for GWR acceptance is the main reason - the projected dates for units being offered to GWR keep going back. In fact Hitachi have been running out of room in the UK for acceptance work and 802 units have been laying over in Munich whilst en route to the UK.
Siemens Staines
30 Jul 2015
This was an 800 this morning. It was a 5 car but I think it should have been a 9.
The diagrams were a bit all over the place today due to the bank holiday. None of the xx15 Paddington - Cardiff ran so the sets that normally would have worked these trains would have done something else instead and that change then rippling out across the day. It was a bit of a double edged sword because a few of those Cardiff trains this morning would have helped to clear Reading of festival goers, but their absence meant that nearly everything was 9-car or 10-car. The Cheltenham you mention was one that wasn't and so to 1L34 0729 Swansea - Paddington with 800003.
Charlie M.
4 Oct 2015
Gloucester
If I come across as a rookie, sorry, but RTT displays it’s a Stoke Gifford ender on the 03/09, and on the 02/09 it’s a Philips Marsh. Is this just the planned or would it have not reverted?
(1742 Paddington Cheltenham)
6 Sep 2016
1A25 1630 Bristol Temple Meads - London Paddington is a HST today, must be covering an IET. 1A24 1600 Bristol Temple Meads - London Paddington also a HST as booked.
robertbishop
5 Oct 2010
Thank you cactustwirly for maintaining this list.
Can I ask if this Saturday's 1A31 1930 BRI - PAD will be and HST or an IET please? Can't see it mentioned in this thread or jimm's IET diagrams thread, so I thought I'd check.
Planning on doing 1W01 on Fri and 1B01 and 1L90 on Sat (the latter as far as Newport), which I'm almost certain are HSTs.
cactustwirly
10 Apr 2013
IET, finishes at North Pole
Mark Webster
29 Aug 2018
Yes b01/b03/1L90 are hst and b79/b88/b94 hst.
robertbishop
5 Oct 2010
Thank you both, much appreciated. 1L90 via Bristol Parkway it is, then.
And welcome to the forum Mark!
6 Sep 2016
1L14 0529 Swansea - London Paddington was a HST yesterday morning, may be covering an IET diagram. 1L20 0559 and 1L32 0659 departures from Swansea to London Paddington also HSTs as booked. This meant that three HSTs were all lined up at Swansea yesterday morning, something that is now very rare.
PHILIPE
14 Nov 2011
Caerphilly
Welcome to the Forum but I hope you don't mind me asking if you have a Shift Key for Capital letters on your keyboard ? I spent a few minutes trying to decode your earlier post
What are 015&022 supposed to mean
If 1b01 is supposed to be the headcode, it should be 1B01 with nothing immediately either side of it. I'm afraid the way you have set things out it makes it difficult to understand even if you understand it yourself. You have just jumbled everything up.
43096
23 Nov 2015
What are 015&022 supposed to mean.
I would have thought it was pretty obvious that it was a pair of power cars - 43015 and 43022 if you still haven’t got it.
How about you stop back seat moderating?
PHILIPE
14 Nov 2011
Caerphilly
I'm glad that you were able to decipher them.
The Prisoner
22 Aug 2012
1203 Royal Duchy Paddington - Penzance was an HST on Friday. Had the delights of.....
No air con in two of the coaches (one of which I was in - lost half a stone)
No food after Reading (sold out)
No hot drinks (boiler failure)
No Pullman service
Felt for the staff who were great tbf - brought round bottles of water and tried to keep a smile on their faces. Train Manager possibly shouldn't have told everyone she had been reporting the air con as faulty for months though. Announced that it was due to to new train deliveries being delayed that one of "the old trains" was running the route, and apologised to people reserved in coach J (?) as there wasn't one due to the reservations being based on an 800/802 (?) formation.
It did feel like the set was a little unloved, and the service was rammed.
Came back on the 1132 Paignton - Paddington today and all was well - HST
CMRail
3 Sep 2018
Gloucester
03/09 (today):
17:42 Cheltenham Spa
IET 5 car.
The only planned 03/09 diagram change that went ahead. Was supposed to be a nine car unit however.
