Reform UK discussion
35B
19 Dec 2011
I do wonder if Tice is simply malicious and in the pocket of the companies who have a vested interest in pushing anti-science views on climate change, or if he is genuinely that deluded that he actually believes what comes out of his mouth.
Firstly, I believe that he is talking from a position of belief. Secondly, I dislike the pejorative way in which his views are being described, as though there cannot be good faith disbelief and disagreement.
What Tice fails to acknowledge is that despite Kent vineyards being able to produce a slightly better wine, the extreme heat in the summers here is leading to severe shock for most of the farming industry. Our water security is now under significant threat, for example.
35B
19 Dec 2011
Indeed - and traders in his constituency are stating that they're losing business because of the heat. I make no defence of the accuracy of his views - merely that the scenario posited by @Tetragon213 is unjustly harsh and, to the extent that it presumes him as in someone else's pocket, underplaying the importance of his own beliefs
Tetragon213
14 Oct 2024
West Midlands
Also they have caused severe shock for quite a large amount of the population.
During the May and June 2026 heat events:
  • there were an estimated total of 2,877 heat-associated deaths
  • an estimated 753 heat-associated deaths occurred during the May heat episode
  • an estimated 2,124 heat-associated deaths occurred during the June heat episode
  • the mortality burden is already close to the highest annual totals previously recorded by UKHSA
And around 42% of those were attributable to climate change
Climate change added between 3-4°C to maximum temperatures and is estimated to be responsible for about 42% of the deaths across both heatwaves
The rise in heat related mortality is indicative of our infrastructure. A lot of these deaths will be vulnerable or frail people in accommodation which is not climate controlled. Just as it was common for "the winter to get you" when frail and elderly, now the summer is doing likewise. It will be interesting to see how mortality rates in winter shape up as a result of an increased number of people dying in summer.
dosxuk
2 Jan 2011
Sounds like a perfect opportunity for another Labour footgun moment when they try to scrap Summer Cooling Allowance.
JamesT
25 Feb 2015
However cold weather kills many times more than hot. If we're overall shifting warmer, this may result in a net reduction in deaths due to extreme weather.
I think it will be hard to tell. The measurement by the government makes absolutely no note of the cause of death or even the demographic profile of the deaths, it just notes the excess deaths during periods of intense weather. In my experience working in a nursing home in the early 2000s, the winter did see more deaths than any other time of year, but I cannot recall an extreme weather event which caused a spike. But that is just a hazy anecdote.
If the North Atlantic circulation shuts down, then we could easily get both; much colder winters due to colder Atlantic waters on our shores, but we could still have heatwaves from the continental Europe influence. The biggest impact though will be drier weather.
Tetragon213
14 Oct 2024
West Midlands
Iirc the UK as a whole is on the same level roughly as Canada, and the weather extremes there are pretty crazy. We're lucky to have enjoyed comparatively temperate weather until now.
With the way climate change is going, we will very much be getting more extreme weather at both ends. Droughts, heatwaves, and fires in summer; and extreme rainfall, blizzards, and flooding in winter. The human cost does not bear thinking about, let alone the economic costs of putting such disasters right or coming up with more extreme mitigations.
Forget about the whole ethical considerations, it just makes plain economic sense to be going after Net Zero and trying to avoid having to deal with the death toll, or the construction of more repairs and extreme measures.
Drier weather will only be an issue if little or nothing continues to be done to harvest and conserve rainfall in the (increasingly) wet periods.
Indeed. This requires very significant infrastructure which would be very very expensive. But Reform don't want to tax anyone who could afford such a tax to pay for it. It's unserious.
35B
19 Dec 2011
I'm not sure how much this is about Reform here, but this post highlights the dangers of pitching net zero vs adaptation. If the weather we've had this summer is a result of climate change (and it is an "if"), then adaptation is already necessary to cope with the climate changes that have already happened.
Going back to Reform, and specifically Richard Tice, the determination to ignore climate change is strange given that his constituency is one of the most extremely exposed to sea level rise.
Sorcerer
20 May 2022
Eventually the focus turns from "climate change is a hoax" and "it's called summer" to "climate change is natural and nothing we can do will affect it". The latter was already circulated within some climate-skeptic circles but it will only increase as the effects become impossible to ignore. Much of the Reform base will insist we had hot summers in the past but this year alone London has had more days above 30c than across the entire 1980s. Then again evidence-based policy isn't exactly Reform's strongpoint.
Sorcerer
20 May 2022
Politics for me seems to be just pointing out how bad other politicians are. Reform just do it to themselves
More specifically I would apply this to adversarial democracies such as our de facto two-party system. I feel like a more consensus-based approached through proportional representation might make everyone a bit less keen on the blame game because the goal is to reach compromise rather than steamroll decisions through the house. Reform do support PR though how long is a question as to whether or not they can benefit from the current system. I imagine Old Slippery Nigel would change his tune to "there are bigger issues the voters care about right now" if polls indicate a massive landslide from first past the post.
styles
7 Dec 2014
Gwynedd
Ah, so you've seen BBC Question Time then :D
Indeed, though I do think it's important for other parties to hold them to account. Partly because otherwise Reform will just ignore the media, not invite them to press gangs, etc in order to bury stories; but also because I think it's healthy that, to an extent, parties hold each other to account and challenge them. It's just that sometimes it gets really tiring, especially when it's just Labour and the Tories blaming the last government for something to do with the economy despite having now been in power for years.
Harpo
21 Aug 2024
Newport
Reform are under investigation by Clacton Council for holding the ‘Farage Fest’, where Nige hid away from ‘nobodies’ for the night after the recent election. The event was allegedly unlicenced as….
Organisers can apply for the ..(licence)…five working days before an event takes place.
The "Farage Fest" application was refused because it was made after this deadline.
A bit like their reasons for the election itself Reform said…
it was "confident that no rules were broken".
jon0844
1 Feb 2009
He has a plan to deal with the risk of rising sea levels.
He'll run as MP somewhere else.
There was a hotly-watched council by-election in Kent on Thursday, taking place in the Dover area and previously Conservative, where Reform UK and Restore Britain were eyeing up victory in the land where the boats they want to stop turn up. In the end the vote split three ways led to the Greens taking it with just 28.7% of the vote and a winning margin of 34 votes. I also wouldn't be surprised if the 45% turnout is unusually high for a council by-election (or even a normal local election vote):
A crunch by-election dubbed the “fight for the right” handed the Green Party an historic victory last night by just 34 votes.
The incumbent Conservatives, Restore Britain and Reform UK’s vote fractured three ways to allow retired GP Ingrid Dodd to take the Guston, Kingsdown and St Margaret’s-at-Cliffe seat on Dover District Council, with the result revealed on Friday morning.
Restore Britain’s 10% of the vote inflicted its first by-election blow to Reform UK’s ambition to take a seat in an area they swept the boards at last year’s county council elections.
On a high by-election turnout of just over 45%, the Greens just edged it on a night of high tension.
When the ballot papers tumbled out of the black boxes at the count, it became clear it would be a straight Green Party versus Reform UK contest.
The by-election was sparked by the resignation of Conservative Martin Bates in a ward held by the Tories for decades. Their candidate, David Hawkes, finished in third place.
The contest attracted huge media attention after Restore Britain announced it would be fielding former Royal Marine Jez Hermer, who is a Kingsdown native, as its first-ever local council candidate.
With three right-of-centre parties in the mix, no one - least of all their candidates - was sure who would win but privately suspected the Greens could prosper.
James Defriend, the Reform candidate and a well-respected Dover county councillor, was widely tipped to win until Restore announced it was running.
In the end, Ms Dodd secured 767 votes to Mr Defriend’s 733.
Ms Dodd said afterwards: “I am absolutely thrilled and delighted - I couldn’t be happier to be representing this ward.
“I was born in Kingsdown, I went abroad for a bit and then came back and worked in St Margaret’s as a GP, so I feel as if the chalk cliffs are in my very bones.
“I am also super happy to be under the auspices of the Green Party because Green principles are in my heart. I think the Green Party is burgeoning as more and more people see the light and realise that we are a part of nature and we are a part of the world and we are only going to save ourselves.”
Mr Hermer said: “The result is exactly what we wanted. We wanted to poll more than we did in the Manchester mayoral election (8.7%) and we’ve done that. It is those incremental steps that we’re looking for.
“Of course, we would have liked to win, but it wasn’t to be.
“To be honest, I thought Reform would win, but I’ll take the result quite happily.”
Mr Defriend did not attend the count held at the Dover District Council chamber in Whitfield.
He said: “As much as I am a councillor and a carpet shop owner, I am also a single dad to three amazing children, and tonight I have my kids.
“I know that not being at my own count will not do me any favours with some people but, the truth is, me being there won’t change the result.”
George Madgwick, spokesman for Reform UK, said after the result was declared: “It’s a good result for us fundamentally.
“It’s disappointing that Restore Britain allowed the Green Party to win this and Restore need to take a look in the mirror. The lesson is that if you vote Restore, you get the Green Party.”
Result
DODD, Ingrid - The Green Party: 767 (28.7%)
DEFRIEND, James - Reform UK: 733 (27.4%)
HAWKES, David - Local Conservatives: 456 (17%)
WISBEY, Steve - Labour Party: 389 (14.6%)
HERMER, Jez - Restore Britain: 284 (10.6%)
WANSTALL, Graham - Independent: 35 (1.3%)
Turnout: 45.08%
Electors: 2,668
Electorate: 5,919
GusB
Elginshire
"Defriend" - is that similar to "unfriend"? ;)
Harpo
21 Aug 2024
Newport
With Burnham arriving in parliament today and Labour on a bit of an upturn, I wonder how Reform feel about their strategy to dislodge Starmer?
Bayum
21 Mar 2008
With the attitudes I see in the volunteer/staff areas, I have to disagree with you quite strongly on that one. The number of volunteers in there who go around slinging the t-slur, with the same casualness that one would order a beer with, is disgusting. Some of the younger folk are alright, but they make up a rather small minority within the rail enthusiast community. Some of the stuff you hear from the footplate crews at other lines when they start talking politics (and don't think anyone's within earshot) would, if said in my professional work/day job office, get you pulled for disciplinary rather fast and rightfully so in that case.
Volunteer organisations should have policies in place so that these sorts of comments can be reported…
35B
19 Dec 2011
As a trustee of a volunteer organisation, that policy work is often competing with a myriad of other things, all of which are urgent. And where behaviours are deep rooted, the policy work is only the starting point - changing hearts and minds is a major challenge
Tetragon213
14 Oct 2024
West Midlands
Bayum
21 Mar 2008
It is. But this behaviour wouldn’t stand anywhere else. I, as well as many others, would have lost jobs many moons ago regardless of ‘changing hearts and minds’. Even more reason to apply the policy without prejudice and make it clear that it will be followed with the appropriate sanction(s) whilst training begins alongside. This day and age, there is absolutely no excuse for this kind of behaviour and slurs to be used in a professional environment.
styles
7 Dec 2014
Gwynedd
Agreed. It wouldn't stand in either of the groups I volunteer with. Though it would be handled sensitively if it was a case of somebody just not having moved with the times. If they remained adamant that they were going to continue using such terms, that would change things pretty quickly. Though the larger organisation I work with does have plenty of diversity training opportunities and people who volunteer or work specifically in that capacity who could be consulted. We would rather retain a volunteer than lose one so we'd do what we could to make things work, but ultimately, there's a clear equality and inclusion policy and if you can't follow it after being offered all the support, we'll have to part ways.
35B
19 Dec 2011
I am proud to be a trustee of an organisation that has such policies and hasn’t needed to go hard on enforcement. But managing change in hearts and minds isn’t always easy, especially in small organisations where the worst offenders may also be key volunteers.
Ultimately, the organisation needs to evolve and take its members with it. The challenge and importance of combining those two needs to be acknowledged.
