Are there other examples in the routing guide of routes where you can travel so many times further than the shortest route for the same fare?
Many.
But don't expect us to attempt to compile a comprehensive list on this forum. The reason is that once such a route appears here, ATOC tend to try to
do something about it.
What they
do about it seldom displays competence. For example, for the journey Woking - Slough, there are three sets of fares:
- route WINDSOR
- route READING NOT LOND
- route + ANY PERMITTED
There are no mapped routes via Windsor, so presumably the ticket is valid by any permitted route from Woking to Windsor & Eton Riverside, then a walk, then by any permitted route from Windsor & Eton Central to Slough. But where can you travel using a Woking - Slough route Reading not London ticket?
In July 2009
embers25 pointed out in
Routing Question from Woking to Slough that, using
maps WR+WX, Woking - Slough was then permitted via Exeter. At that time travel was not permitted via Gloucester.
After a series of events, during which the treatment of
embers25 reflected very badly on the railway industry, the Routeing Guide was changed with effect from 7 August 2009.
National Routeing Guide said:
Permitted Route Identifier, 2 July 2009
Woking - Slough LONDON WR+WX
Permitted Route Identifier, 7 August 2009
Woking - Slough LONDON LW+WX
As a result of this change, Woking - Slough via Exeter was removed as a permitted route. Woking - Slough via Gloucester was introduced as a new permitted route.
The route via Gloucester was removed by another change to the Routeing Guide with effect from 16 October 2009.
Permitted Route Identifier, 16 October 2009
Woking - Slough LONDON RG+WX
This latest change has still left an unsatisfactory position. Avoiding London, the only Woking - Slough mapped routes over which a train service operates are:
- WX: Woking - Surbiton - Wimbledon - Clapham Jn - Barnes - Richmond - Twickenham - Feltham - Staines - Ascot - Wokingham - Reading, then RG: Reading - Slough. (77.25 miles)
- WX: Woking - Surbiton - Wimbledon - Clapham Jn - Barnes - Hounslow - Twickenham - Feltham - Staines - Ascot - Wokingham - Reading, then RG: Reading - Slough. (78.5 miles)
At present these much shorter, more obvious routes are not mapped routes:
- Woking - Farnborough Main - (walk) - Farnborough North - Sandhurst - Reading - Slough. (42 miles)
- Woking - Chertsey - Ascot - Reading - Slough. (47.5 miles)
- Woking - Aldershot - Ash - Sandhurst - Reading - Slough. (50.5 miles)
- Woking - Ash Vale - Camberley - Ascot - Reading - Slough. (52.25 miles)
- Woking - Basingstoke - Reading - Slough. (56.5 miles)
