Peter Sarf
I have been using NiMh batteries since 1999. Over the years I have found myself questioning why I bother.
1) I have noticed many of the batteries fail after 5 - 20 uses. To be fair most use is camping so once a year.
2) I am not sure they are really cost effective.
3) They are of course no use for devices that insist on the correct voltage - NiMh cells voltage is actually only 80% of a normal battery.
4) PP3 I had some and they were particularly useless.
5) Each year I waste a lot of time checking their voltage, charging them all and then testing them a few days later.
6) I had reasonable life with non-rechargeable Alkaline batteries. Well they don't have much of a re-use life when I do recharge them but its not much worse than the NiMhs.
7) I have found them good for LED torches as LEDs seem to not be very voltage specific.
8) I have three suitable chargers. One on timer and head detection. Two more intelligent that can discharge, tweak and re-charge.
9) I have two old beast chargers that I use on Alkalines. As this is supposed to be dangerous I charge them on the patio in fine weather !. The patio is not a thing of beauty !.
EDIT :-
10) Forgot this one. Years ago I noticed that the C and D rechargeable batteries are quite expensive and often have no better capacity than my AAs. It felt like the D cells were in fact an AA with a spacer round them due to their weight. Behold in Maplin (so a while back) I one day noticed a set of D cell size plastic cases that you could insert an AA into. The biggest benefit is I no longer have to keep C and D cells charged ready to use and so have also not had to go to the expense of replacing them as they die. The AAs are cheaper and large capacity ones are more available. So I recommend the C and D adaptors sold on the web. Ironically I still have two of my original 8 D cells hanging on for grim death. They (4 at a time) only get used for the camping airbed inflator. It is amazing how some from the two sets have lasted longer than other identical members used and charged at exactly the same time.
/EDIT
What are other peoples experiences ?.
EDIT :-
/EDIT
