Reason behind the Sleeper's call at Watford Junction
BlueLeanie
21 Jul 2023
Haddenham
Curious about the reasoning behind the Sleeper's call at Watford Junction.
Is it simply a suitable holding/timing spot before it continues onto Euston if it's running too early or is there a more historic reason?
With the opening of East-West in early course would a call at Bletchley or Milton Keynes instead drive improved connectivity?
sh24
28 Sep 2023
Bus connection to Heathrow I believe, along with that's what it's always done .
paul1609
28 Jan 2006
K
I think it dates back to the dedicated rail air link to Heathrow per sh24 but realistically the connection to the 06.52 West London Line service to East Croydon via Clapham Junction is going to provide loads more connectivity than East West is ever going to.
telstarbox
23 Jul 2010
Wennington Crossovers
Why would you connect to Heathrow onto a non guaranteed bus rather than having a guaranteed connection on a domestic flight from Scotland?
12LDA28C
14 Oct 2022
The ‘Sleeper’ has called at Watford for as long as I can remember, picking up heading north and setting down heading south. I’ve never considered this noteworthy, any more than a WCML train to or from Liverpool or Glasgow calling at Watford.
Djgr
30 Jul 2018
It probably just a throwback from the days when many WCML trains called at Watford Junction and nobody has seen reason/noticed to change it.
The exile
31 Mar 2010
Somerset
May be daft if you’re coming from Edinburgh / Glasgow itself, but less so from Aviemore / Fort William / Montrose etc. However, I suspect that the real reason is historic but that there’s no pressing reason to change it, so why bother?
A S Leib
9 Sep 2018
Although the Highlander hasn't called at Watford Junction since 2020 (northbound) and longer (southbound), as far as I can remember, which reduces that benefit.
Looking at old Wikipedia pages, it looks like the southbound Highlander hasn't called at Watford Junction since at least 2006, and that until 2014 the Fort William portion served Westerton instead of Glasgow Queen Street low level.
The exile
31 Mar 2010
Somerset
Although the Highlander hasn't called at Watford Junction since 2019 (northbound) and longer (southbound), as far as I can remember, which reduces that benefit.
Shows how long it is since I was an occasional user!
A S Leib
9 Sep 2018
I might have got the exact year wrong, although it definitely served Watford Junction immediately pre-Covid and doesn't now.
BeijingDave
26 Jul 2019
Watford itself is a conurbation of nearly 100,000 people. Makes sense to put in a stop before London in some ways, and have more potential sleeper customers.
The exile
31 Mar 2010
Somerset
And it’s not as if the few minutes it costs are material on a sleeper journey.
jfollows
26 Feb 2011
Wilmslow
Yes, May 2019 1S25 called at Watford Junction to pick up, at 21:34, but 1M16 passed in the up direction at 07/30. As you said earlier.
cle
17 Nov 2010
The Sleepers should both definitely call at Watford. It's not long in/out of Euston to be disruptive - and at night people don't want to change so having a railhead is better (vs changing or trekking into Euston) - and it covers a whole swathe of North London and Herts/Bucks, much beyond the town of Watford itself. Which is not insignificant.
It's the busiest station on the WCML between London and Birmingham/Manchester (Queens Park, Willesden Junction and Wembley Central hover around the 8-10m range when combined with tube) - and after HS2 should see more calls back.
A S Leib
9 Sep 2018
Of course there's a lot of differences (time of day, proximity to London suburbs / M25, population, air and daytime rail alternatives), but has the Night Riviera always called at Reading in recent history?
Hertfordshire County Council's 2015 rail strategy had a goal of all long-distance services calling at Watford Junction. I can't find the source right now, but at another point the aim was 2 tph to Birmingham and 1 tph to each of Liverpool and Manchester, which feels more realistic (can probably do without a Watford – Chester / north Wales link).
sh24
28 Sep 2023
Pretty sure the Night Riveria has always called at Reading, and back in the 80's also Bristol TM and Taunton too.
Krokodil
23 Jan 2023
Wales
The Night Riviera has to stop in a number of places to waste time to avoid arriving too early. It certainly called at Taunton when I last caught it from there (2016), I believe that it doesn't do so on a Sunday night/Monday morning in order to facilitate diversions via the Mule.
irp
14 Aug 2023
Cov, UK
While drifting off topic, The Down Night Riviera stops at Reading to pick up passengers, but also to drop off the rear loco [which ever one it may be], so it can then be used to drag the ECS to Paddington for the next night's service
Failed Unit
26 Jan 2009
Central Belt
I think back in BR days it was for the M25 traffic. Luton, Stevenage also had the same justification as others have said. A North London park and ride. Less express services stop at any of them now. But this is just a throwback,
The exile
31 Mar 2010
Somerset
The outer London stops long predate the M25, though.
cle
17 Nov 2010
And Stevenage has had a renaissance. Watford/WCML by far and away has more tph which makes it harder. The ECML is much sparser - although continually growing and more OA floating around off-cycle!
Luton for long distance is dead, Corby aside (and I question that need) - and it is less used than Airport Parkway, if another Luton area stop was ever required, it'd be there.
Horizon22
Jobs & Careers
8 Sep 2019
I was going to say the loco move is also an important factor for the Reading call.
A S Leib
9 Sep 2018
As well as going from a bihourly York service (alternating with Lincoln) to an hourly Newcastle service from December on top of Lumo.
This has been done on other threads and is going off-topic, but if HS2 to at least East Midlands Parkway had gone ahead and if the Universal theme park gets built, I think at least one hourly long-distance call for either Luton station or Bedford would be warranted.
