RealTimeTrains website
IanXC
Emeritus Moderator
18 Dec 2009
I'd say it's more signaller intervention (whether that be automated by ARS or not is a different matter!) but essentially yes.
If the thing with the TOC comes off, then it'll be similar to Darwin in that respect. That should open some floodgates in that area, rather like ScotRail and train allocations...
Ah yes I was thinking of a areas where routes can be set such as NX panels that don't even have train describers, but you've defined it better.
Oh interesting look forward to seeing what you've got in the works! Of course they biggest problem in this area is where ACI and set swaps argue with each other.
midlandred
20 Feb 2007
Oxfordshire
Sorry to butt in - it’s probably been asked and answered before - some passenger and freight movements, RTT shows loco/unit, but not all.
Is there an accessible site which shows more than RTT?
Thanks
Intercity110
31 Jul 2022
64Mi 64Ch (Approximately)
Thanks
Railcam gives TOPS where it has them, and the specific freight companies, not just ‘ZZ’. (Tops allocations require a subscription, but this gets you signalling diagrams as well)
XAM2175
8 Jun 2016
Thanks
This is a special arrangement between the operators concerned and RTT. The official data from Network Rail contains no allocation information at all.
Merle Haggard
20 Oct 2019
Northampton
Now I know pathing times don't reflect traction used BUT...
Today, there was a slightly odd Avanti 16.33 Birmingham International to Euston, worked by double Voyagers.
But it's shown on R.T.T. as 'pathed for 125 m.p.h. diesel loco', and I know that doesn't mean it should be a 125 m.p.h diesel loco.
But the only possible 125 m.p.h. diesel loco is a Cl 67, and I thought that running at 125 was heavily proscribed.
Are 67s cleared for 125 m.p.h. on this route - perhaps dating back to Wrexham & Shropshire?
As far as I can tell, other Voyager turns are shown as 125 dmu.
It will be timed as a Voyager.
Thats 1B52, normally a New St starter, and a double voyager, and always timed as ‘125 diesel loco.‘
amended to an International start until the timetable change, I believe.
XAM2175
8 Jun 2016
Right, thanks, I think I understand (my bold); but what's the significance of 'Pathed as'?
Pathing and timing are the same thing in this circumstance; showing it as loco-hauled instead of an MU is just one of those oddities of the planning process. Sometimes it's simply down to there not being the correct class-specific pathing data available for the route.
Other times it's simply become convention. Off the top of my head, the Class 325 postal units are usually pathed as "Electric locomotive, trailing load 325 tonnes" ;)
Merle Haggard
20 Oct 2019
Northampton
Thanks, just seems an odd train - it's 5 minutes behind the Preston - Euston via W Mids, and the New St starters usually leave International at about nn.58. I hadn't noticed it before, thought it was a one-off to get sets from Central Rivers to Euston in service.
Edited curse Apple auto correct!
Oh thanks.
If we look at RTT in a bit more detail, 800002 is shown arriving into platform 2 at Paddington off 1L76 1259 Cheltenham Spa to London Paddington
https://www.realtimetrains.co.uk/service/gb-nr:C97872/2023-04-08/detailed#allox_id=1
It then went to North Pole Depot as 5L76 at 1518, on a working not on RTT, with the pair of 387s working the service shown on RTT. (I guess that in the usual timetable it works the 1550 departure, but GWR are using 387s instead.)
It is possible to see this here (ignoring the fact that it has got mixed up with a Crossrail empty stock working), noting the departure from platform 2.
Tom
19 Jan 2008
35,000ft
The electric/diesel loco, timed at <insert unit> tonnes is somewhat annoying and we try and clean it up on our side with a filter by timing load and operator. Looks like there’s a couple more to do soon.
On another note, there will be a refresh of all the delay and cancellation codes in a coming release later this week.
XCTurbostar
13 Sep 2014
Many thanks for your efforts. Is there any possibility of a line under each TSC with what it means? e.g. 54606070 - RfD Freightliner (Contracts)
Tom
19 Jan 2008
35,000ft
I don’t think there’s a reliable frequently updated data source that provides that information so it would be a bit of a challenge to do so as I’d rather not add to the list of manual admin requirements.
XCTurbostar
13 Sep 2014
Fair point, there is a redacted .xls which has most of them but its a moving target.
Benjwri
16 Jan 2022
Bath
Is there any way RTT could expand on the info as to the next scheduled working of a unit? There is limited support, I believe through associations, but other sites are able to give next workings for pretty much every service, and this is the only function that I still can’t use RTT for.
357
12 Nov 2018
And for those people actually traveling as a regular passenger, it would also make it easier to see where the "inbound" stock is for their train.
Tom
19 Jan 2008
35,000ft
The sites that have extended associations I suspect are either using something called inferred associations so aren't entirely guaranteed but are done through a couple of different systems. One of those is going to be Darwin so <insert reasons for being unable to use Darwin because the railway are precious, repeat ad infinitum>. The other I think is a system that we as a business have access to but I don't think we're actually permitted to use it in the public domain... but I will go away and ask a few questions.
There are a few quality of life improvements on the way for KYT, which may go some way to mitigating it for those TOCs.
louis97
14 May 2008
Derby
On RTT we recently did an update to some of Train Describer reference data used to generate the reported times.
It would be really helpful if people could PM me any reports showing with "TRUST Smart" as the data source (hover over a reported time). Ideally a link to the train in question and what location would be great. I'm looking for examples where it is an odd report doing this, not a whole area missing (such as the whole Macclesfield area which we are aware of). Secondly any times that are wildly incorrect would be good too, we have a list of locations but I highly suspect there are more.
Benjwri
16 Jan 2022
Bath
Thanks! I definitely know of one public source which doesn’t use Darwin and provides this, but to be fair it could be their own internal algorithm which just looks for the next/last arrival into the booked platform. Just helps at large stations where otherwise you have to scroll through and it’s easy to miss a service.
MrJeeves
28 Aug 2015
Burgess Hill
https://www.realtimetrains.co.uk/service/gb-nr:L45745/2023-04-19/detailed
Clapham Junction, Balham, Earlswood (Surrey), Purley all show as TRUST (Smart) :)
