RealTimeTrains website
_toommm_
8 Jul 2017
South West London
Noticed today that ‘Service passed another here’ has been replaced with ‘Service stops for pathing (passing train)’, such as this train, 5Z66, from Edinburgh to Edinburgh via the Suburban Line:
Class 466
5 Mar 2010
Atherton, UK
The former made more sense IMO
Oh dear. This adds even more confusion, as "A" stops aren't always to pass another train.
The simplest explanation would be "service stops for pathing reasons". You can't determine the reason for the stop in any automated fashion (you'd have to look at the graph).
If you wanted to add any more detail you'd have to enumerate the main reasons, e.g. "service stops for pathing reasons (to pass/be passed by another train or await its onward path)". Obviously that's too long.
It often didn’t make sense though, the code was being applied more often to the train being passed, rather than the one doing the passing, as was discussed in this thread a couple of weeks or maybe months ago…
Tom
19 Jan 2008
35,000ft
I think you're putting too much onus on RTT to correct railway errors here. RTT is effectively a window onto the railway and how it thinks it is running.
We had some discussions internally about A/X activities and changed it mostly for grammatical reasons - and it changed about a week ago.
The A activity is "Stops or shunts for other trains to pass" - whether it is passing or being passed by another train is neither here nor there in my eyes. It's still a passing train. The X activity is "Passes another train at crossing point on single line" - near enough the same thing really. Just because it is being used in other cases isn't really my problem to fix.
The new wording doesn't make a great deal more sense gramatically though. The bit in brackets should be "(passing a train)" or "(to pass another train)" if anything.
I get that you've got to work with the imperfect industry data as it stands. But people who are intimately involved in the timetable process are telling you that the "translation" you've adopted doesn't reflect the way that the A activity is actually used. I don't understand why you are reluctant to go by that, and are insisting on using the technical (but not entirely helpful to members of the public) TPR definition.
Tom
19 Jan 2008
35,000ft
Three things to consider. There is a character limit on what can go in that section. I have had, other than in this place, as far as I can tell two or three comments about the terminology (which were about tense). In the current front end code, A/X are deliberately grouped given that they are fairly similar in purpose (i.e. the action of passing another service). So, on that basis and with the constraints, I am inclined to believe that in general there is an understanding of what the intention is.
I am not really sure what the hang up is about this - the definition is fairly reasonable as it still involves passing a train (whether it is the one stopping to be passed or vice versa I think does not matter much) whether one readily exists or not. For those who are wanting to use RTT in a more planning/operational way, there are facilities to see the raw codes underneath via the commercial platform.
Western Sunset
23 Dec 2014
Wimborne, Dorset
Ye olde WTTs phrased it like this:
X - Indicates points (a) at which the train is booked to run from one running line to another, (b) at which trains are booked to cross each other on a single line at a crossing place.
Like Tom above, I'm not hung up about semantics. RealTime Trains is a top-notch resource that I find most useful. Long may it continue.
D6700
13 Mar 2010
Simply describing an "A" stop as "Pathing Stop" would be very short and accurate. As Watershed has explained, the stop isn't necessarily to let a train pass - it is often because there isn't an available path further down the line.
Tom
19 Jan 2008
35,000ft
I now understand a bit better about where you are coming from. However: I would have to stick with the rules as they are stated in the documentation that is made available as otherwise it would just be contradictory to other systems that stick with the word of the documentation.
If the purpose of something has changed, then it should be updated in the TPRs, CIF documentation, BPLAN, etc, as otherwise it would be one system changing something on the word of those from an internet forum rather than from the official source. The railway is very good at changing meanings without changing the docs that everyone has to rely on. If there is evidence that I have missed to suggest as such from official sources then can I suggest it is sent to the feedback@ address so that they can look into it on there.
BRX
20 Oct 2008
Well, I'm happy that it's changed so it's not in the past tense, which is what felt wrong about the old version, regardless of any arguments about technicalities.
Roger B
16 Jun 2018
Gatley
I took a trip to Scotland earlier this week - including a visit to the SRPS at Bo'ness - hugely enjoyable. I see that many of the TPE trains to Scotland are still marked 'Reservations compulsory'. However this is not now the case, with on train announcements pointing passengers to a carriage that has no reservations. I daresay that this is another instance of RTT displaying the information provided from its feeds, buf if that's the case, I think it's pretty poor that TPE (and possible other TOCs) aren't actively maintaining this data. Doesn't their oontract with DfT require them to do so?
"Aren't actively maintaining" is too charitable, I'm afraid. As I've said elsewhere, it's not a change that happens by accident.
Sheridan
11 Jan 2012
I’m with you on this, the only thing that grated on me was that it was ‘passed’ rather than ‘passes’, when all the other activity descriptions are in the present tense. Just changing the one letter would have done for me!
Roger B
16 Jun 2018
Gatley
A question of much greater significance than when / whether this or that TOC shares their allocations / know your train data with RTT, is whether GBR are going to do so. And to date the only rumblings I've heard haven't been that encouraging.
Hopefully someone's heard more encouraging news?
TT-ONR-NRN
30 Dec 2016
Cambridge
And what rumblings might those be?
Still hoping for Greater Anglia to make an appearance to help with the 720/1s when they arrive :lol:
Same! I’m waiting for GA
As am I, desperately :lol: I’ve been on 67 of the 720s now, and so even when they’re all in use I’ll be encountering plenty of duds!
AlexNL
19 Dec 2014
Wasn't 43184 outshopped just this week? Someone will have to make the appropriate graphics for it first, before those can be linked to the loco on RTT.
D6130
12 Jan 2021
West Yorkshire/Tuscany
I've noticed on RTT over the past couple of days a glitsch in the Northern unit allocations. The unit numbers have been correct, but many of the unit formation graphics have got into the wrong order. e.g. a picture of a class 333 unit with two driving motor cares nose-to-tail at one end of the unit! :s
