Reading to Maidenhead then Windsor-Farnborough
Bill Badger
28 Nov 2008
I wish to travel from Reading to Maidenhead, walk along the Thames to Windsor and then return to Farnborough. I have a Reading to Farnborough Season Ticket and am trying to find a cheapest way of doing this.
The simplest would be to buy a single from Reading to Maidenhead and another from Windsor to Wokingham, but I suspect there may be a better way.
I thought maybe a Reading to Windsor return would be the best bet as the routeing points for both Windsor stations are Slough and Staines, but the prices are different, depending which way you go so they don’t appear to be interchangeable. A Reading to Datchet tickets looks better as the fares for both routes appear to be the same. Would that be valid?
Cheers
OwlMan
25 Jun 2008
If yo are after the cheapest then CDR Reading to Windsor & Eton Central reyurning to reading and then from Reading to Farnborough all variations using Datchet or Riverside are more expensive
Peter
wintonian
15 Jan 2010
Hampshire
There’s a good value Thames branches ranger around that will get you from Reading to PAD and all the bits off it including Windsor for £15.50
Or a 3 in 7 Thames Rover for £40 allowing you to go PAD to Basingstoke, Banbury and Redhill.
All are available with a railcard discount, so about £26.50 or £10ish
FGW leflet
