And for going to Gatwick, surely there will be a fairly substantial proportion of passengers with luggage who won't be that keen to change trains.
100%
They do read the forums, so I’m sure it was noticed and corrected quickly!it looks like someone (maybe GWR) has fixed it
But -- Reading resident here. We'd never even contemplate fannying around in town with the EL / Thameslink option.
Nothing's ever straightforward with the railway, is it? I was going to suggest Reading to Clapham Junction then change for Gatwick. However, this link https://www.southwesternrailway.com/travelling-with-us/at-the-station/reading implies Contactless is valid for SWR from Reading but that doesn't tally with the map referenced earlier in the thread. If Reading accepts Contactless and so does Gatwick, how is the customer meant to know that despite paying using Contactless, that method of payment is not acceptable for some trains. With the current pretend renationalisation, it's ludicrous that the railway can't get its act together.
Especially when the train that it is not valid on is a direct train that, literally, starts at Reading and terminates at Gatwick.If Reading accepts Contactless and so does Gatwick, how is the customer meant to know that despite paying using Contactless, that method of payment is not acceptable for some trains.
There's a rule I believe about valid routes which says that a route is always valid if there's a direct train. Perhaps the same needs to apply to contactless.Especially when the train that it is not valid on is a direct train that, literally, starts at Reading and terminates at Gatwick.
It would certainly avoid a lot of the problems and confusion you see at the moment.There's a rule I believe about valid routes which says that a route is always valid if there's a direct train. Perhaps the same needs to apply to contactless.
Could the problem be that there is no route, nor indeed a ticket for contactless? Well, not until the journey has been completed and tapped out correctly.
That applies to tickets bought before travel, and only those routed 'Any Permitted'. Contactless simply works by calculating the fare for any journey within the contactless area, but restricts travel to being within that area.There's a rule I believe about valid routes which says that a route is always valid if there's a direct train.
But not to contactless.It also applies to tickets bought during or even after travel.
Define "the area". SWR's website refers to Contactless being accepted at Reading and then waffles on about services to Waterloo. But there's no definition of an "area" that includes Reading and Waterloo, so what does Joe public conclude?That applies to tickets bought before travel, and only those routed 'Any Permitted'. Contactless simply works by calculating the fare for any journey within the contactless area, but restricts travel to being within that area.
Define "the area".
Likewise, isn't there a rule that a route is valid if it is the shortest route between two points? I would have thought a direct train from Reading to Gatwick would have met this requirement.There's a rule I believe about valid routes which says that a route is always valid if there's a direct train. Perhaps the same needs to apply to contactless.
This is what I found when searching for Contactless on the SWR Website. This map clearly shows only the inner suburban stations with services to Waterloo.Define "the area". SWR's website refers to Contactless being accepted at Reading and then waffles on about services to Waterloo. But there's no definition of an "area" that includes Reading and Waterloo, so what does Joe public conclude?
Possibly that this is another rail industry shambles being trialled in one part of the country before being rolled out as a semi-national mega-shambles. The result of which is paying customers being penalty fared or having significant sums of money extorted from them under threat of being taken to court?
Experts might know it's inaccurate but the average customer will see that contactless is available at Reading, contactless is available at their destination and the operator of the contactless fares system quotes them a price. At what point are they meant to know that it's the paint job on the carriages that determines if they're going to end up "fined"?I really wouldn't take very much on the Reading page on the SWR website as gospel considering they're also claiming they operate the direct service to Bristol via Swindon (which is obviously a GWR service). I don't recall them ever having operated the Sunday-only 158/159 services from Reading (that normally terminate at Salisbury) to Bristol via Salisbury either, and if they did, it certainly would've taken a lot longer than 1hr14m, so it can't just be extremely outdated info. (I think it did go to Exeter from Reading on a Sunday at one point though). You could shave off a good 5-10 mins from their Waterloo claim too for the most part.
It seems that Reading, Gatwick and Virginia Water are currently in the rather odd position of you being able to catch trains where both ends of the journey are in the contactless area, but the middle isn't. It doesn't help that TfL will give you a contactless fare between these two points [Reading and Virigina Water] even though you can't use that to get a direct train between those points.
As an aside, I wonder if you would be charged £9.60 to make the journey if you went via London
They probably actually mean their own Tap2Go contactless PAYG, although I wouldn't be surprised if they fail to be clear about thatJust been invited to complete a survey on PAYG ticketing whilst on an SWR Waterloo to Reading service!
It's a DfT survey on Feb's contactless PAYG extension. Ironically I've only used this route since July so can't report a great improvement due to contactless because I've never used anything else on this route!!They probably actually mean their own Tap2Go contactless PAYG, although I wouldn't be surprised if they fail to be clear about that
A survey skewed to get the answer the people commissioning it want? Heaven forbid!My view is that the questions are writtten in such a way that you're going to say you're in favour of contactless.
