Reading Green Park Station
MarkyT
20 May 2012
Torbay
Can anyone explain the thinking behind 2 platforms each 150m long
Not long enough for an 8car EMU (if line is ever electrified), but far longer than a Voyager (if cross country were ever to call) and rather longer than a pair of 165 or 166 DMUs. Almost feels like a round number regardless of length of trains
Only just too short for 8x20m=160m, so should be possible for such a train to call, maybe with 1 passenger door disabled (or 1 car's doors depending on capability of SDO system in use). I Don't see any likelyhood of XC calling under normal circumstances. In my experience using the line regularly over a decade ago, a 2 or 3-car turbo was usually perfectly adequate for peak passenger numbers on the stoppers.
Winthorpe
18 May 2019
Based on the mockup, pasted below, used in the media release they are expecting an Avanti Pendolino to call at the station :lol:
MarkyT
20 May 2012
Torbay
Wow, and they're clearly proposing to convert them to bionic duckweed power as there's no sign of any kind of electrification. I expect they'll disable the tilt capability when they're transferred to GWR so there'll be no need for any TASS.
fgwrich
15 Apr 2009
Hampshire
A 2 car certainly isn't adequate or ideal anymore, that I can tell you! The only thing I'm looking forward to with the glacial introduction of the 769s is having 4 cars on the branch, as that will certainly help to spread the load out a bit.
It's all First Group these days anyway :lol: Still, give it a good run up from Southcote and it might just make it beyond Green Park.
Kite159
27 Jan 2014
West of Andover
It still won't stop the rear coach being the busiest on departure from both Reading & Basingstoke, because some passengers are lazy ;)
MarkyT
20 May 2012
Torbay
Or have just made it on board at the nearest door before departure after running from a mainline connection.
mangyiscute
6 Mar 2021
Reading
I don't ride on the line too frequently, perhaps once per month, but usually when I take it (often around evening peak times) a 3 car train is adequate, perhaps all 2 seaters are taken and some people have to sit next to someone but that is fine in my opinion. However, I would be worried for reading matches, and I also haven't tried it in the school rush
kevin_roche
26 Feb 2019
markymark2000
11 May 2015
Great Britain
Why is Green Park taking so long to build? Maghull North was built in 8 months, Reston built in 14 months (based off start build till open to the public). We are now quite far into the development here and it still looks like it could be a few months off. Is work just very slow here? What is slowing it down?
fgwrich
15 Apr 2009
Hampshire
It certainly seems to be somewhat glacial, I noticed from those photos that the platform isn't even fully surfaced yet.
kevin_roche
26 Feb 2019
It looks to me like most of the nearby buildings are unfinished and still being worked on. The road to the new station is still part of a building site and not yet open. The article linked in post #120 also implies that the money to finish the station has only just become available.
73128
8 Dec 2019
Reading
There are completed homes nearby and also a lot of offices. A lot more houses under construction too. The Madjeksi stadium will be around 10-15 minutes walk.
ewsclass
27 Jun 2020
Fleet
It's now the 'Select Car Leasing Stadium' haha. it's been very painful to watch this station every day indeed, incredibly slow progress
fgwrich
15 Apr 2009
Hampshire
Indeed! It's been a few seasons since London Irish left for well, London, so sadly I have little need to use it now!
73128
8 Dec 2019
Reading
Went down there again yesterday. The station is now signed, with a double arrow outside and there are two bus stops and the car park has been surfaced (and has three motor cycle spaces). No obvious cycle parking though is visible. The down platform is numbered one and the up as two. The steps to the footbridge are signed as an emergency exit from the up side (fair enough) but that on the down side is equally signposted as such towards the car park, which seems silly and dissuades access from the few houses over to the west of the line. I suspect it will end up open most of the time...
Reading Buses have just told me that they do not plan to serve the station....
fandroid
9 Nov 2014
Hampshire
Just passed by on the Basingstoke shuttle. There's new cable ducting under construction between the new station and Southcote junction
73128
8 Dec 2019
Reading
Another visit today. Appears largely complete and there are just a few snagging items to sort out and a slightly greater electrical issue. New signs all now up. Balfour Beatty staff seem to think that opening is planned for late this year, which ties up with December timetable change opening that I have read elsewhere.
fgwrich
15 Apr 2009
Hampshire
I did notice it has now appeared in the CIS Screens too. Unsure, but I believe they have now included it in the GWR Turbo PA system.
Are there still two rows of tactile pavers on each platform?
AlastairFraser
12 Aug 2018
It might be for shuttle buses to the Mad Stad, which should be about 5 mins each driving down Longwater Avenue and Northern Way.
Reading Buses route Greenwave 50 is only about 5 mins walk away and will serve most of the area you'd want to get to from the station itself.
Kite159
27 Jan 2014
West of Andover
Just crawled past the station (on the SWR running early) and it looked like the ticket barriers have been installed in the main building.
73128
8 Dec 2019
Reading
Reading Council tell me that construction of the new station is due to complete by the end of this year, following which a safety process is to be observed prior to station opening. Once the Office of Rail and Road have authorised the station, early next year, a formal opening date will be announced.
