Reading Buses and Thames Valley
Deerfold
26 Nov 2009
cactustwirly
10 Apr 2013
markymark2000
11 May 2015
Great Britain
There only seen to be two new services there (neither of them cross-town).
To be fair, the council is being extremely flexible with the timetable. As long as it fits within some 'essential' parameters, the rest looks quite flexible and open for operators to plan their own timetables and routes. Operators must fit criteria 1, 2 & 3, desired criteria is 4, 5 & 6, nice to have criteria 7, 8 & 9. I'd say it's probably quite open for a bus operator to run a cross town service if they so wish whether by merging the contracts or commercial extensions to tenders.
Fletcj10
28 Apr 2023
Reading
I do wonder if RDG keep the 3 if they might invest in new electrics, i think the 127/8/9 might be best to just go to carousel or even just the 127, the issue i love is the ghost air 500 every time i see that theirs maybe 2/3 people on and that's it, even RA1 at Winnersh doesn't seam to do trade, i don't think it did either at TV P&R
sp503
12 Jul 2023
Reading
RA1 usage in Winnersh is much better than the TVP&R days. I have once seen 5 or 6 families alighting at Winnersh from one RA1 bus. Of course it’s nothing close to Reading Station but is a respectable stop.
The 500 has seen its ridership rising after adding the stops along A4 and Kings Road. The ridership isn’t too bad during the rush hours, but the usage of Winnersh P&R in general can be better. Though honestly with e-commerce so mature and so many vacant offices in Reading, what could one expect.
Tramtrain
22 Aug 2019
Northumberland
Last time I checked the RA website, tickets weren’t available for purchase from Winnersh Triangle or vice versa.
There is some flexibility, but it’s more constrained than that suggests. For Lots A–C, operators bid for the whole Lot, so individual elements cannot simply be picked off and combined with another service. Alternative tenders can combine Lots/services, but the underlying tender criteria still apply.
Looking at the actual specifications, the council is also quite prescriptive in places. For example, the 128/129 replacement (F4) must run in the peak via Coppid Beech, Wokingham Station and Winnersh Crossroads to Twyford; off-peak it must also serve Broad Street, Hurst and Broad Hinton. So although the route is nominally operator-designed, that effectively leaves very little freedom and makes the proposed Coppid Beech park-and-ride journey to Twyford rather circuitous.
The 124 is another example. Its replacement sits inside the wider Lot B Wokingham Town Services, alongside the 121, 122, 123 and 125/A/B. The tender actually says the Waterloo Road/Easthampstead Road area should be incorporated into a longer route. Extending Route 3 would seem an obvious way of doing that, particularly as the separate Route 3 tender encourages minimising layover at Broad Street. But Reading Buses can’t just bid for that 124 element alongside Route 3 without also becoming involved in the wider Lot B package.
So there is flexibility, but the way the Lots and some of the Must criteria have been constructed actually makes otherwise logical cross-town combinations harder to deliver.
Trainman40083
29 Jan 2024
Derby
Streetlite RE63 EOG appears to be at the Notts and Derby depot, in Derby. Seems 3 are coming.
Mollman
21 Sep 2016
Preston
Reading have announced some service changes from next week including a reduced frequency on the 5 and 50/50a to every 15 minutes.
lime 2changes to departure times and additional school day journey
leopard 3route change in Arborfield
emerald 5changes to departure times with buses running up to every 15 minutes
emerald 6/6a changes to departure times
purple 17changes to departure times
claret 21increased frequency in on weekday mornings and evenings, minor changes to departure times
greenwave 50/50achanges to departure times with buses running up to every 15 minutes
little oranges 19a/19cthe 7.40am 19c service will now start at Royal Berkshire Hospital on school days
little oranges 19badditional 19b journey at 7.16am on school days from Chalfont Way
https://www.reading-buses.co.uk/timetable-changes-tuesday-1-september
buslad1988
28 Dec 2018
21 is a permanent frequency cut to every 20 minutes too
I had a feeling that might be the case when they started repainting the deckers, wasn’t there a bus removed from the 26 as well?
Presume the 20 White Knight will be back?
Mark L
12 Dec 2023
West London
I must admit I’d have thought that of the two Emerald routes the 6 would have had the lower loadings. The frequency cut on the 5 will mean it’s no longer possible to offer a six minute headway between the station and Whitley on the combined service. I do wonder whether the 6 will go down to x15 in due course.
Fletcj10
28 Apr 2023
Reading
I mean llooking back at when the EV's first entered serivce they had extras (17 still does) for peak workings which have now been dropped in favour of generics, makes you wonder what the emerald order will be i.e how many of those for the route given they have 3 now and what they will be used for after the new new ones enter serivce
