Sprigibax
At the moment it is difficult to make the section from Rayners Lane to Uxbridge step free to train due to the difference in sizes between the deep level and sub surface trains. Here are two solutions I’ve come up:
1 - The Piccadilly line is removed from Uxbridge. A new sub surface line is created, running from Edgware Road to Wimbledon and Kensington Olympia (taking over the current District line service) and also taking over the Uxbridge service from Earl’s Court. This would make the whole section sub surface, and allow the Piccadilly line to run more Heathrow trains. If the Piccadilly line took over the Ealing Broadway branch, as planned, the new line could also serve Chiswick Park.
2 - The Metropolitan line is removed from Uxbridge. The Jubilee line is extended from Wembley Park to Harrow and then takes over the branch. The whole Rayners Lane to Uxbridge section would then become deep level. In this instance, the Central line could then also have a branch to Uxbridge from Ruislip Gardens, either in addition to or in place of West Ruislip.
Will either of these plans be possible, and if so, which is the better solution?
