Rare solar storms could cause rail network chaos, scientists warn (BBC)
InkyScrolls
20 Jul 2022
North of England
Rare solar storms could cause chaos on the UK's railways by triggering "powerful magnetic disturbances", scientists have warned.
A study at Lancaster University found the celestial events could disrupt the network's electrical systems and cause signals to switch from red to green.
Researcher Cameron Patterson said the "relatively rare" storms needed to be "taken seriously" by the rail industry.
However, Network Rail said it considered the risk to be "very small".
Is this scaremongering from the university (my alma mater, though a very different department!), or something actually worth noting?
greyman42
14 Aug 2017
No doubt we will hear it announced over the station PAs as the reason for cancelled/late running trains.
" The next train is cancelled due to a rare solar storm"!
Lucy1501
9 Nov 2021
Cumbria
Rare solar storms will cause a lot more problems than just the railway!
To put it this way, everyday tons of radiation blasts the earth, some gets through the atmosphere, and an even smaller amount just so happens to hit computer hard disks, flipping a bit and corrupting data.
At a larger scale, this has the ability to cripple computers on power grids, water distribution networks, and other critical infrastructure.
With the move to computer based interlocking the risk of this is somewhat higher than before. Old magnetic relay installations also have a chance of being affected. That being said, the chances of this happening are incredibly slim, and there’s tons of redundancy in interlocking.
Modern day computer based interlocking uses something called majority voting. There are multiple computers all working on the same thing, and they all vote on the result. By doing this, if one or two have made an error, they are overruled. Similar happens during communications.
Previously came up here in 2022, as discussed in this thread:
The same university department, fancy that…. o_O
This made the front page of the Daily Star, under the headline "Euston, we have a problem".
Peter Mugridge
8 Apr 2010
Epsom
A solar storm knocked out a lot of stuff in Canada about 30 years ago, so yes - it can happen if it's strong enough and aims straight at us.
MotCO
25 Aug 2014
Presumably it will affect all the data stored in clouds :D
15 May 2023
Minster
I read a while ago about the effects of solar radiation on railway signalling systems and that a lot of it has protection from events like this?
AndrewE
9 Nov 2015
Let's hope that the majority / all of them haven't been fried then. Nothing would move for a long time.
If that was the case (don't the military call it "hardened?") I am sure someone in authority woud have trumpeted it by now, so the answer is "probably not!"
BBC? Take it with a pinch of salt.
Yes, of course they are all pinkoes trying to undermine the government.
If you had suggested that it might be another bit of Russian-inspired disinformation intended to weaken our confidence in our infrastructure I might have thought you had a point.
Merseysider
Fares Advisor
22 Jan 2014
Not quite sure what you’re on about there :lol:
Deepgreen
12 Jun 2013
Gomshall, Surrey
I'd trust the BBC over the Daily Star any day! Of course, as control systems become more and more delicate and based on finely-tuned electronics, the risk grows. The same applies, I assume, to trains' systems, and all other such electronic networks. The issue, presumably, is will the failures be safe-side or not.
flitwickbeds
19 Apr 2017
I remember the sky was going to fall in on January 1 2000.
And it only didn't because of the many, many hours of work put in by programmers to fix systems before this date.
There is another, similar, although much smaller, event going to happen in 2038. Programmers are working now to ensure no impact on that date.
Trackman
28 Feb 2013
Lewisham
It's absolute twaddle. We had a major solar flare a couple of years back, I didn't see any signal aspects changing or interfering with GSMR. Things are built very differently these days.
stuving
26 Jan 2017
It's the same PhD student, Cameron Patterson. He started in 2021 with a description of what he'd be doing, and rehashed that last year for another conference. I can't see any sign of a new publication, so maybe it's just reporters not checking the history.
The point of his research is that DC track circuits can be affected by the geomagnetic currents that flow in the ground underneath them. That's true, but it's also quite easy to observe and measure. So is the change in the geomagnetic field that drives the currents, so you can correlate the two and thus predict how big a magnetic disturbance could cause a wrong-side failure.
That's roughly what the planned research was, using some measurements to be taken by Atkins. Inevitably these days it involved him modelling the relevant stretch of line (Preston-Lancaster) and its environment. I did wonder how easy it is to find stretches of main lines still using DC track circuits, as it's being replaced and I don't think any is now being put in. And the disturbance is a DC current, so other forms of train detection are not affected.
15 May 2023
Minster
Yeah I just found the same story. Remember reading it on Ian visits last year.
