Raised Platforms North and South Bound on the Thameslink
PathFinderUK
6 Aug 2023
Camden
Hi. Does anyone know which platforms are raised for easy access with wheelchairs on the Thameslink on either direction? Is there a list anywhere? Thanks.
Failed Unit
26 Jan 2009
Central Belt
All stations in the core for a quick starting point.
London Bridge, Blackfrairs, City Thameslink, Farringdon, St Pancras International.
Are you meaning the ones outside the core? I can’t think of any on the ECML that have raised access.
PathFinderUK
6 Aug 2023
Camden
Thank you!
Generally platforms can only be raised to be level with a typical train entrance (about 1100mm above top of rail) if the track in question isn't used by freight trains, as they will foul the higher platform. So it's only seen in a few places - Elizabeth Line central section, East London Line, Heathrow and the Paddington HEX platforms, and many stations on the Underground sub-surface lines (and possibly a few others I don't recall). The other option is a train with lower entrances, but Thameslink doesn't have these.
