Railway stations with entrances in a shopping centre
miklcct
2 May 2021
Cricklewood
Welwyn Garden City has its station entrance in a shopping centre. This makes me feel like home (Hong Kong) where a significant number of stations have entrances (for some stations, all entrances) in a shopping centre, for example, Ma On Shan.
Which stations in the UK, in all railway systems, have entrances in a shopping centre? Among them which have all entrances in a shopping centre?
davews
24 Apr 2021
Bracknell
St Pancras International to all intents and purposes has its entrance in a shopping centre..... OK in that case the station came first.
NSE
3 Mar 2010
Bond Street. Elephant and Castle NR used to.
Starmill
18 May 2012
Bolton
Birmingham New Street, Bicester Village, Braintree Freeport, Canary Wharf - where do you draw the line?
Skie
22 Dec 2008
Liverpool Central and Southport both do too.
Liverpool Central even had a subway passage directly into the basement of the nearby Lewis's department store.
Basil Jet
23 Apr 2022
Don't know it well enough to comment
Bicester Village,
It has an entrance that faces the car park of the shopping centre, but also has a main entrance
Braintree Freeport,
The station is in the car park of the retail park, but not really what I think the questioner intended
Canary Wharf -
The Liz station is part of the same building as the shopping centre, but you could use either without thinking about the other.
I would have nominated Wrexham Central (and Welwyn GC) as the obvious ones. Maybe Hammersmith D/P and Fulham Broadway.
25 Aug 2019
Lancaster
Does Edinburgh Waverley? Most times I try to get to the station proper I go through a poky little mall, although I have managed to find at least one other entrance, down a long ramp for vehicles.
30907
Bicester Village
....is next to the Village car park, but (pedantically) not the shopping centre. And it has a "normal" access too.
Metrocentre was, IIRC, opened with access only from the Centre, but that's no longer the case. Meadowhall was always accessible from "outside," not sure about Chafford Hundred/Lakeside.
29 Nov 2018
I suppose Waverley does, if you use the term 'station' loosely. The shopping centre (another loose definition) has doors onto Waverley Steps which in turn lead you to the walkway above the concourse. Technically Network Rail may well own Waverley Steps too.
Other station entrances can be found from Market St and Calton Rd, plus those you already know from Waverley Steps and Waverley Bridge (x2 former vehicle ramps).
fgwrich
15 Apr 2009
Hampshire
Kelvinhall Subway is rather tucked away behind the shops along the Dumbarton Road in Glasgow, While Argyle Street is similarly tucked away.
geoffk
4 Aug 2010
Exeter
Aberdeen is connected to the Union Square shopping centre.
...and the bus station is the other end of it, so if you're changing from train to bus or v.v. you have to walk through the shopping centre.
Starmill
18 May 2012
Bolton
There's an entrance that's only there because it's connected to the shopping centre. That seems to fulfil the criteria as loosely defined. Whether there's another entrance isn't one of the limitations given.
Jimini
8 Oct 2006
Reading
Fulham Broadway and Hammersmith (mentioned above) immediately spring to mind here.
Mikey C
11 Feb 2013
From memory, there is a direct connection from Stratford into the Westfield Shopping Centre?
Canary Wharf DLR is within a shopping centre of sorts
gazr
24 Mar 2014
Does Doncaster count? Entrance is off to the side and up an escalator.
Dr Hoo
10 Nov 2015
Hope Valley
Willesden Green station, as rebuilt in 1925 by the Metropolitan Railway, was regarded as a seminal design in its day. No fewer than seven shops had a frontage onto Walm Lane and all of the railway facilities were located behind them. The rail customer would also have passed one of two further retail kiosks before actually reaching anything useful, such as the large parcels office, left luggage office and finally the ticket office.
There was no shortage of bright ideas in the Cricklewood area even 97 years ago!
Jimini
8 Oct 2006
Reading
Tough one. Technically they're next to each other, but both entrances are outside, albeit under a covered area (next to the smoking area).
adamedwards
4 Apr 2016
We were up there at the weekend and there was no way in without going through the shopping centre. The shopping centre also links to the bus station and with only one road crossing the terminal for the Orkney and Shetland Northink ferries.
CyrusWuff
20 May 2013
When it first opened back in 1995, the link from Chafford Hundred to Lakeside was provided by a (free) shuttle bus.
The footbridge over the A126 opened in 2000, at which point the shuttle was withdrawn. Ensign's route X80 now provides an hourly service between the shopping centre and station at a cost of £1.20 Single or £2.00 Return.
