Railway interview tips
uww11x
9 Sep 2012
Hello all,
Has anyone got any tips for Railway interviews. I have one coming up but don't want to say where at this stage.
Is it a good thing to declare you like trains when they ask about hobbies etc?
Dynamonic
10 Jan 2013
Nottinghamshire
Interviews can vary depending on the role you have applied for, so the best thing to do is look up the competencies for the role you are after and think of some examples in which you have demonstrated them in the past.
You will probably be asked questions in the form of, 'Give us an example of a time when you...'.
When asked questions in that format, try and provide your answers in the 'STAR' format. This stands for:
Situation (What was happening?)
Task (What was you expected to do?)
Action (What did you do to resolve the situation?)
Result (What was the outcome of the situation?)
You should demonstrate a passion for the role you have applied for and of course the railway, but try to avoid coming across as too much of a rail enthusiast, as you may create the impression that you may not be totally focused on the task at hand.
Also, do plenty of research on the company you have applied for.
Good luck! :)
Cyclist
5 May 2018
Use the search feature on these boards to look for people discussing similar roles and similar interviews. Nearly every position has been discussed at some point.
uww11x
9 Sep 2012
Good luck! :)
Smashing info,
Thanks
OxyBoxy
10 Feb 2018
Another good thing is take a quick look at competency interview formats. Don't read too much from Google otherwise you'll overwhelm yourself, but just look at the job role and think about some examples
LA50041
20 Feb 2017
Also in many cases it's worthwhile reading up on the company's vision and values in case you get asked about them
uww11x
9 Sep 2012
Cheers for the tips guys. Had the interview and think it well.
I was asked if I had holidays planned and what my notice period was.
Does that mean they were interested?
Harbornite
7 May 2016
I think they're just standard questions.
By the way, I'm assuming you wore a suit and tie? This may seem obvious but I'm just curious.
OxyBoxy
10 Feb 2018
They'll all that if everyone. The only real way to tell is wjen they let you know. A good interviewer won't let on
red2005
9 May 2009
north ish
Yes standard questions as they may still need to plan course dates etc, so they need to know who can start on what dates if they’re successful.
