Railway General Knowledge.
Rutland23
31 Aug 2020
South Witham
Oakham Brooke crossing box disappeared many years ago, along with the crossing itself some time later (after a fatality, I believe.)
The remaining boxes along the line are :
Frisby
Melton Mowbray
Whissendine
Ashwell
Langham Junction
Oakham
Manton Junction
Ketton
Uffington & Barnack
along with two staffed level crossings at
Wyfordby
and Wymondham.
Apart from the two manned level crossings, which have no control over trains,
Only one of the above signal boxes can be switched out.
Which one, and why?
Regards
Ian
Gloster
4 Sep 2020
Up the creek
Having looked at the track diagrams, I will rule myself out. However, there is an obvious reason why most of the boxes can’t switch out: this leaves two and I can make an educated guess as to which one can switch out.
Rutland23
31 Aug 2020
South Witham
All the 'Boxes along the line are manned 24/7, and currently there seems to be enough reliefs to cover holiday or sickness.
How long that lasts, I don't know.
But there have been times when the shift at Melton has not been able to be covered, or he has been redeployed to cover a short term shortage at another box.
It is still the only box which can be switched out along the line.
Why?
Regards
Ian
Rutland23
31 Aug 2020
South Witham
Because it's the only box without a level crossing?
Correct.
All the other boxes control 1 or more level crossings on public roads.
Melton has control of 4 user worked/accommodation crossings as well as the Barrow Crossing at the station (for disabed access to the down platform), which can all be switched through to Frisby if it needs to close.
@D6130, you have the floor.
Regards
Ian
Calthrop
6 Dec 2015
I'm certain that it was before Mussolini allegedly sorted these general matters out ...
Edited to add -- Embarrassing confession: something just stirred in my memory -- looked back via the "search" facility; and yes, roughly two and a half years ago I set a question on "Railway General Knowledge", about the dates (year) of rail nationalisation in a bunch of different European countries -- including Italy ! Date thereof, I had looked up for the purpose; and subsequently forgotten :oops:. Obviously in these circumstances, I can't submit as an answer here, this which I now know. Senile dementia looms ...
martinsh
27 Jan 2011
Considering a move to Memphis
Would you like to guess the exact date for the bonus glass of prosecco before setting the next question?
I haven't a clue !
So on to the next question
What operational feature is shared by the following stations
Chester
Derby
Exeter St Davids
Redhill
NB this isn't a complete list, but there aren't many others in this category
RDP
1 Jan 2023
Kent
I know my previous answer is wrong as i have now worked out the correct one.
These are all through stations where trains reverse en route. Birmingham-Holyhead at Chester, Cardiff-Nottingham at Derby, Exmouth-Paignton at Exeter St. Davids, Reading Gatwick at Redhill and Kings Cross-Bradford at Leeds. One could also add Shrewsbury (Birmingham-Aberystwyth), Birmingham New Street (Reading Newcastle) and Reading (Manchester-Bournemouth) to the list.
martinsh
27 Jan 2011
That's correct - well done !
I also came up with Ely, Bristol Temple Meads, Castleford, Gloucester and Sheffield
Your turn to change driving cabs
RDP
1 Jan 2023
Kent
Try this one.
It is possible to get to London in both directions from Margate, Broadstairs, Ramsgate and Dover Priory stations but which is the odd one out and why?
