Railway General Knowledge.
Calthrop
6 Dec 2015
John Fowler and Hamilton Fulton put forward an alternative scheme to what - and what did they suggest should be done instead?
I thought that they worked in different parts of the world -- Britain and North America respectively? As it's April 1st, I'm going to say: they proposed, instead of using ships, a tunnel between the two -- a real-life version of Harry Harrison's 19th-century-set fantasy tale, A Transatlantic Tunnel, Hurrah !
EbbwJunction1
25 Mar 2010
Newport, South Wales
I don't know about the two of them working in different areas, but I can say that the project they jointly proposed was located in the UK.
Oh, and it's got nothing to do with todays' date!
Calthrop
6 Dec 2015
Without cheating -- I truly haven't the slightest idea.
Hamilton Fulton and John Fowler
Collaborated on a great howler --
They're in the jailhouse now.
EbbwJunction1
25 Mar 2010
I think that this has gone on long enough, so I'll give the answer, which is the Severn Tunnel.
This from the Great Western Archive:
"With economic pressures, several schemes were put forward for a crossing of the Severn as several railway companies vied with each other for the lucrative coal trade. The most popular schemes were crossings by a bridge as tunnelling was seen as a risky and unpredictable method. One scheme that was put forward was by John Fowler and Hamilton Fulton was for a high-level viaduct 2¼ miles long entitled 'The South Wales and Great Western Direct Railway'. Standing 120 feet above high-water level it was to have three openings, one of 600 feet and two of 265 feet. At a cost of £1,800,000, it was to be a formidable undertaking, however, the risks to shipping avoiding the bridge supports in addition to the mists and fogs of the estuary were hard to calculate. Nevertheless, the planning for this bridge, or 'Fowler's Line' as it became known, received parliamentary approval.
At the same time, Charles Richardson, who with 25 years experience of tunnelling which included Box and Thames Tunnels, presented a case for a tunnel under the Severn. He argued that a tunnel would carry none of the risks of a bridge and it would cost just £750,000."
The Great Spring is open to anyone who wants to drink from it .... !
Welshman
11 Mar 2010
What links 30 years of spiritual music in 20c. Liverpool with the Pennsylvania Railroad?
Welshman
11 Mar 2010
OK - this may be a little too esoteric, so I'll give the answer now.
The link I had in mind was the name "Philip Duffy"
A Philip Duffy was a contractor of the Philadelphia and Columbia Railroad, which became part of the Pennsylvania Railroad. The line passes through "Duffy's Cut" - built in 1832 - and the site of a cholera pandemic which killed nearly 60 Irish navvies.
Meanwhile, back in 20c. Liverpool, Dr Philip Duffy was Master of Music and a composer at Liverpool Metropolitan Cathedral for 30 years from its opening to 1996.
Open Floor.
Cowley
15 Apr 2016
Devon
I'll give it a go then.
In the first few years of class 47s being operational, four of them were written off. Three of these were in serious accidents but what happened to the fourth?
The three crashed ones were:
D1671 (the original THOR)
D1734
1908
Which was the other one?
Cowley
15 Apr 2016
Devon
Wasn't it the one that had an uprated engine & it blew up injuring the driver?
That's the one. D1562s engine exploded in March 1971 after being experimentally uprated by Stratford depot, near Haughley Junction on a Liverpool Street to Norwich service and as you say the engine room door blew off and broke driver Harry Hendrys arm. The explosion and fire caused so much damage it was deemed uneconomic to repair.
I'm not sure what power the engine was actually uprated to. Can't find any info on it anywhere.
Over to you Mr Tra.
theageofthetra
27 May 2012
Beckenham
Keeping the experimental theme. Why did an ancient and lowly Victorian Midland Railway 1F 0-6-0 become a bit of a ground breaker in 1931?
Cowley
15 Apr 2016
Devon
Would it be the first diesel electric shunter?
Cowley
15 Apr 2016
Devon
What about the English Electric 6KT power plant as eventually used in the 08/09s etc? The first time it was used in a shunter? That seems like about the correct era.
TheEdge
29 Nov 2012
Norwich
To expand on Cowley's answer. First diesel shunter to receive a diesel engine driving traction motors attached to the axles (as they do in the 08 family) rather than via chain, gearbox or other mechanical methods?
theageofthetra
27 May 2012
Beckenham
One more guess before I give the answer.
Cowley
15 Apr 2016
Devon
I looked it up in the end as I had no idea. Interesting though.
theageofthetra
27 May 2012
Beckenham
The correct answer was that is was converted into a diesel hydraulic shunter under the LMS and was the first UK locomotive to be fitted with a Paxman engine. It wasn't particularly successful and ended its days as a portable generator and was broken up in the 50's.
Open compression ignition floor
Calthrop
6 Dec 2015
The semi-official names in railway jargon, of various steam loco wheel arrangements (Atlantic, Pacific, etc.): which one of these was (as a side-effect of a large-scale conflict) altered, over some of the world for a time, to a different -- but rather similar-sounding -- name? Please give the wheel arrangement concerned, and the original and modified names.
Calthrop
6 Dec 2015
Hint (following on from EbbwJunction1's post): the modified name sounds and looks a good deal like the original “Mikado”; including, same initial letter. It’s the surname of an individual person who was closely involved in the conflict mentioned in original question: on the opposing side in same, to the country with which the title “Mikado” is associated.
