Railings blocking Edinburgh bus passengers
Adlington
3 Oct 2016
An example of good planning....
Passengers trying to get off Edinburgh’s new 100-seater buses are being left confused at some bus stops when the middle doors open and their exit is blocked by railings.
Lothian buses said it carried out a detailed route evaluation before introducing the eco-friendly double deckers. But former councillor Dom Heslop said there were several stops along the Lothian Road corridor where the exit doors open directly onto kerbside railings.
https://www.scotsman.com/news/trans...le-doors-of-new-100-seater-vehicles-1-4919102
DunsBus
12 Jan 2013
Duns
Nothing new - when LRT ran dual-door Olympians on the 9 out to Armadale back in the early 90s, passengers alighted them at Livingston bus station via the front door as the centre exit was blocked by railings. Folk seemed to manage fine back then; I certainly don't recall it making the papers at the time!
GusB
Elginshire
Is dual-door operation really so beyond the wit of man/woman/insertwhichevergendertermyou'recomfortablewith? It really isn't so long since Edinburgh abandoned dual-door operation - it's within living memory for most adults, surely? When you consider that most LB vehicles haven't had centre exits for a few years, surely instinct would be to revert to recently-learned behaviour and walk to the front of the bus?
SteveP29
23 Apr 2011
Edinburgh/ Chester le Street
Instead of bombarding you with incessant sh**e about 'this is xxx stop, blah blah blah' surely the automated crap can say 'this stop has railings, please exit at the front of the bus'
Go North East tried the rear exit doors with their 21 and 22 Angel buses 10 years ago, they didn't last long, people simply wouldn't get off at the rear doors.
computerSaysNo
14 Dec 2018
Except that whenever you try to exit using the front door, the driver tells you off for it.
I was recently the only person on a dual-door number 11 service, I wanted to get off using the front door so that I could thank the driver (there was nobody wanting on at the stop I was getting off at so it wouldn't have caused a delay), when I went to get off at the front door the driver complained that I should be using the rear door.
Adlington
3 Oct 2016
I wanted to get off using the front door so that I could thank the driver [...], when I went to get off at the front door the driver complained that I should be using the rear door.
Did you thank him anyway?
Yes, I thanked her and then she told me off for getting off the front door.
Quite right, as by doing so you will have been lengthening the dwell time at the stop - even if by the couple of seconds it takes to walk forwards. A couple of seconds at every stop add up.
If you want to thank a driver with dual-door operation, which works superbly in London and just about everywhere else in the world, give them a cheery wave and a smile in their nearside wing mirror, they'll be looking in it to do the doors.
Regarding railings, that occasionally happens in London and it just requires common sense.
Adlington
3 Oct 2016
Of course telling somebody off has no effect on the dwell time.
61653 HTAFC
18 Dec 2012
Even when the council runs the buses, it seems the right hand doesn't know what the left hand is doing. :rolleyes:
I'd expect (and experience) something like that round my way, where kerbs are Council responsibility, bus stops/shelters are PTE responsibility, and the buses themselves are the responsibility of the national government (of Germany)!
carlberry
19 Dec 2014
And people ask why bus passenger numbers keep on falling!
computerSaysNo
14 Dec 2018
I pressed the buzzer and went and stood by the front door long before the bus reached the stop. If anything, using the front door saved time as it is quicker to open and close than the rear door.
One of the main reasons passenger numbers keep falling is that bus operation is incredibly slow. One way to speed it up is to have boarding/alighting from separate doors, as they can then happen concurrently. If you combine that with 100% off-bus ticketing, as demonstrated in London, it is possible to get a dwell time just as low as a conductor-operated bus.
Having a chat with the driver on boarding and alighting is a key reason that slows it down.
Countries that take bus travel seriously do not have a setup where passengers need to have conversations with the driver about anything at all.
90019
29 May 2008
Featherstone, West Yorkshire
With the routes the XLBs are currently on, it's literally just the two stops at Morningside primary that the centre doors can't be used at, it's really not a big deal or even vaguely newsworthy.
All the regular passengers know about those two stops and come up to the front anyway.
The stops on Lothian Road, it's just a case of not opening the doors as far back as you can with a single door bus.
Jordan Adam
12 Sep 2017
Aberdeen
In Aberdeen with your Artics you can use either door to exit. It just comes down to common sense. For example at the busier stops you use the rear door. But at the Bridge Of Don end of the route where you normally only have people going on or off and not both it's more logical to use the front door.
If you were the only passenger getting off and it's a quiet out of city stop then to me that makes perfect sense, as i say it's what would happen in Aberdeen. Of course Lothian being Lothian they have to make a bit fuss about everything!
richw
10 Jun 2010
Liskeard
Several other ‘design’ faults on various buses or stops.
Several drive in reverse out bus stations the bay kerbs for passengers don’t come out far enough for Optare Solos.
The raised kerbs the council’s installed at the time of high floor step entrances are too high for low floor buses to use the wheelchair ramp, there’s several stops we have to raise the ferry lift, or stop clear of the actual stop if a wheelchair user wishes to get on or off! The bus floor is lower than the kerb!
Darklord8899
6 Jul 2018
I believe the set of railings at the Caledonian hotel as mentioned in the article have now been removed to allow dual door access
