Rail Roll over at Marcel, California (23/10/25)
Ploughman
15 Jan 2010
Near where the 3 ridings meet
There was another derailment at Tehachapi or nearby, one comment I have seen says 3000ft of rail rolled over under the train.
On Thursday, October 23, 2025, at approximately 08:44 a.m. CDT, we received a preliminary report of a train derailment near Marcel, CA which has affected the main track. BNSF personnel are responding to assess the affected area. The estimated time for opening the main track has not been determined at this time.
If your loaded shipment(s) is directly involved in the incident, a member of the BNSF's Load and Ride Solutions team will contact your company's representative within 24 hours of the incident with relevant information and next steps.
What would be the cause of rail roll over in this sort of scenario?
ac6000cw
10 May 2014
Cambridge, UK
What causes Rail Roll over?
AFAIK it's usually a combination of excessive side (lateral) force on a rail and/or defective/weak rail fastenings.
It's quite twisty through Marcel - it's basically sharp S-curves on a steep gradient (see the aerial view in the second video above at 6:55). Tehachapi Pass is nominally a 2.2% gradient between Caliente (at the bottom) and Tehachapi (the summit), so long heavy trains will have high longitudinal (along the train) forces, some of which translates into lateral forces in curves.
This is a ground-level view of a train climbing through the Marcel area (starting at 16:34), heading south/east (my video from a visit there 10 years ago). The squealing is quite noticeable:
