Rail Properties
musicking1306
10 Jun 2012
Bristol
Does anybody know what the materials that rails are made up from as I have to complete a A Level Physics coursework on this subject. I know that that it is made from Carbon steel and made at Tata steel works in Scunthorpe. If anybody knows anything about the alloys that make it more durable then it would be greatly appreciated.
Class172
Quizmaster
20 Mar 2011
West Country
Doesn't the manganese alloy add extra strength to the rail, as otherwise wouldn't it slowly squash out as weight was applied above?
Boodiggy
8 Nov 2012
Network Rail are now using HP (High Performance) Rail at specific locations. It is harder wearing and is meant to reduce RCF / GCC and require a lower grinding frequency.
Ediswan
15 Nov 2012
Stevenage
There are at least two ways to take that question. You may get marks for a good answer to the less obvious way. Best to check before trying though.
1: What are new rails made of ?
2: What are the rails you run over every day made of ?
Answer 2 could be very different to answer 1. Rail can last a long time. Chances are some of Merthyr's finest is still in use somewhere.
musicking1306
10 Jun 2012
Bristol
2. What are the rails that you run over ever day made of? ,I am looking into the materials properties and what alloys give the rail its properties, for my A Level coursework.
