Rail Maps- interchange symbols.
glbotu
8 Apr 2012
Oxford
So, I'd recommend some reading of some of the "map reviews" from http://www.projectmapping.co.uk
It gives a bit of insight into your question.
Short answer is no, although generally it depends on what stations the map maker (or their boss) wants you to interchange at (certainly with the tube).
Eg: South Kensington is displayed as the Circe/District/Piccadilly interchange, rather than the earlier station of Gloucester Road. That's because it's always a straightforward cross-platform or same-platform interchange, or going straight down the escalators. There's basically more space for interchanging passengers at South Kensington, which doesn't exist at Gloucester Road. Same with Baron's Court/Hammersmith.
There are published design standards somewhere for LU line diagrams, basically they only show an interchange symbol at the first or last opportunity depending on direction.
As it happens there was a short discussion about it in the LU sub forum only a few weeks ago: http://www.railforums.co.uk/showthread.php?t=109226
Another thing you'll usually find on an LU map is that if there is parallel running with National Rail the double arrows to indicate interchange only appear at the ends of the shared section, not all the intermediate stops. Helps to reduce clutter.
Jonny
10 Feb 2011
Also, Gloucester Road has no escalators at all; the Piccadilly platforms are lift-only (well lift-and-stairs only to be precise).
