nascar24
- Joined
- 22 Dec 2012
- Messages
- 18
On Youtube are several videos of 50008 at Exeter recently hauling some rail grinding machines. Where and when were these machines built?
ATB
Alan
ATB
Alan
ATB
Alan
DR 79200-B by Gareth Rawlings, on Flickr
Newark Northgate by DarloRich2009, on Flickr
DR79226 Northampton 090815 by Dan Adkins, on Flickr
C21-01 6Z01 Falkland DGL - Upperby Jn. Carlisle 13.05.15 by Michael's North Briton Railways, on Flickr
Watford Junction by DarloRich2009, on Flickr
DR 79301 Loram Rail Grinder Bristol Temple Meads by Bob Spiers, on FlickrMilling is basically (relatively slowly) chiselling away bits of metal using a set of cutters mounted around the circumference of a wheel or shaft. (A lathe is the opposite - the work-piece revolves against a stationary cutter).
Grinding is using highly abrasive wheels rotating at high speed to basically scratch away (abrade) the material - the tiny bits of metal (dust almost) that are removed get very hot due to the friction involved, producing a shower of sparks (so you have to be careful about lineside vegetation catching fire in dry weather).
Used to fix different track issues - grinding deals with rcf
Fortunately I do know what that is.![]()
You need to look out for overnight STP schedules with a 'service code' of [53693803]Been wanting to witness one on the go for a long time now and am looking for any way to get a heads up of its duties?
I've a strong feeling I'm going to get something like "when the rails need it", but is there any periodic set diagram(s) for touching up the rails? Or is it indeed purely as required?
Why are some of these beasties as big as seven cars? Are there repeated sets of grinding gear that pass over the track?
Yes - the big ones grind over areas many miles long and make only one pass.
A supplementary question then, do they have different grades of grinding wheel along the length, as well as different angles and profiles, a sort of "coarse to fine" progression IYSWIM, which would make the whole train single direction use?
So tonight for example, there is this working (6Z01) from Dundee:
http://realtimetrains.co.uk/train/U78788/2017/08/03/advanced
Another (6Z02) from Kings Norton:
http://realtimetrains.co.uk/train/U35207/2017/08/03/advanced
..and this one (6Z03) from Woking:
http://realtimetrains.co.uk/train/U79107/2017/08/03/advanced
http://realtimetrains.co.uk/train/U79108/2017/08/04/advanced
Are any of those suitable?
MARK
Exactly right.
Do grinders always use that particular service code number?
I am asking because there's this unusual movement in for tonight:
http://www.realtimetrains.co.uk/train/O16986/2017/08/03/advanced
MARK
That will be one of the Network Rail 'Robel' trains:
https://www.networkrailmediacentre....eels-set-to-revolutionise-railway-maintenance
...although they are not entirely dissimilar to a rail grinder in outward appearance:
MARK
Based on the headcode (6U84), it would have been number four.Yes - I stayed up and saw it through the trees.
Any idea which one it was? I still need numbers 2, 4, 7 and 8 for sight...
Number 2 has been working off Paddock Wood and number 7
is currently based at Wakefield Kirkgate. (I don't think that 8
is in use, perhaps it's kept as a spare?)
MARK
