Rail access points
Stuart-h
27 Feb 2013
Bit of a long shot but does any one know of any links to network rail acess points at all?
Tomnick
10 Jun 2005
If it's something that you need, then it's something that your employer ought to provide rather than expecting you to fish around on web forums for it. If nothing else, how are you expected to work safely after getting onto the line at an unfamiliar access point with no instruction from whoever's planned the work?
GB
16 Nov 2008
Somewhere
Theres a document called the emergency plan which is produced by Network Rail. Its in diagram format a bit like the sectional appendix but lists access points, level crossings and bridges. If this is what your after then speak to your line manager who should be able to get you a copy.
IanXC
Emeritus Moderator
18 Dec 2009
If this information is required for your job role, I'm not entirely clear why you wouldn't have it provided?
In any case, I don't think posting such a link on the forum would be wise.
