Quickie - routeing for Reading<>Bodmin Parkway
LexyBoy
23 Jan 2009
North of the rivers
Pretty sure about this, but just wanted to check as none of the booking sites will accept it.
With a Reading-Bodmin Parkway SSR, am I OK to travel via Cheltenham on the return? Seems to be allowed by maps SW+WR, but just wanted to confirm.
soil
28 May 2012
For a journey from Plymouth Group to Reading, you can use maps SW, SW+WR, WE, WR, WR+SW, or ZZ.
That is Bodmin - Plymouth, then
Plymouth-Taunton
Taunton - Westbury - Reading
OR
Taunton - Bristol Temple Meads - Bath Spa - Swindon - Reading
OR
Taunton - Bristol Parkway - Swindon - Reading
OR
Taunton - Westbury - Bath Spa - Swindon - Reading
OR
Taunton - Westbury - Bath Spa - Bristol Temple Meads - Bristol Parkway - Swindon - Reading
All using maps ZZ, SW, WE or WR.
SW + WR and WR + SW do not give any extra options.
In particular, Bristol - Cheltenham Spa, Cheltenham Spa - Swindon - Reading doubles back between Standish Junction and Cheltenham Spa, including the entire section Gloucester-Cheltenham Spa.
This is shown clearly on Google Maps, http://maps.google.co.uk/maps?q=sto...use,+Gloucestershire,+United+Kingdom&t=m&z=14 but not so clearly on the routeing guide.
hairyhandedfool
14 Apr 2008
Double-back applies to stations (you may not pass through a station more than once), not lines or junctions. As far as the maps are concerned, via Cheltenham IS a valid route on maps WR+SW provided you do not go via Gloucester in both directions. However I have not checked any easements so there may be one prohibiting this.
LexyBoy
23 Jan 2009
North of the rivers
Thanks chaps. Having looked at times I'll probably actually be breaking at Cam & Dursley and resuming at Stroud, so won't actually be travelling via Cheltenham/Gloucester (although following the same mapped route).
Easement 700093 allows doubling back between Gloucester and Cheltenham in any case so even if travelling via Gloucester both ways it's not a problem.
bb21
Emeritus Moderator
4 Feb 2010
Also permitted is going Exeter St Davids - Basingstoke - Reading, as that is no more than 3 miles longer than the shortest route.
[Table 135] Bodmin Parkway - Exeter St Davids - Westbury - Reading: 216.5 miles
Total: 216.5 miles
[Table 135] Bodmin Parkway - Exeter St Davids: 78.75 miles
[Table 160] Exeter St Davids - Salisbury - Basingstoke: 125 miles
[Table 122] Basingstoke - Reading: 15.5 miles
Total: 219.25 miles
