Southern Region/Signal Repeating AWS (SRAWS)
Originally called "Southern Region AWS", its name was later changed to "Signal Repeating AWS". The SRAWS system repeated the next signal's aspect (and displayed a reminder of the previous signal's aspect) on an indication inside the cab. Any aspect other than green had to be acknowledged by the driver pressing the correct button that corresponded to the indication on display. If the driver did not acknowledge the indication, or the wrong button was pressed, an automatic brake application was initiated. The risk of error from subconscious cancellation was therefore greatly diminished.
Above: SR AWS Cab setup. Development of SR-AWS, with signal past indications on left and signal approach indications on right. Note the km/h only calibrated speedometer.
During 1971 an experimental form of cab signalling (SRAWS - Signal Repeating AWS) which was being trialled in the up-direction between Byfleet [it may have been Woking] and Raynes Park (as well as in the New Forest area). The cab layout showed the driver the aspect of the next signal and the one that the train had just passed. Its used a coax aerial loop figure of eight in the track with a frequency module in the signal location to pass a radio frequency code to the train depending on the signal aspect. Development of SRAWS ended in 1975 when the British Railways Board dictated that the Southern Region should equip its lines with standard BR AWS.
